Old 08-10-2018, 12:25 AM   #1
StrnWolf
StrnWolf has a spectacular aura aboutStrnWolf has a spectacular aura aboutStrnWolf has a spectacular aura about
1994 SL1
Default What Does Factory Exhaust System Look Like?
On my 95 SL2 I was under the car to replace a coolant hose, and it appears to me that the exhaust system may not be OEM, and in CA if you change the exhaust system you fail inspection. I did not take a deep look but what caught my eye was a random screw that appears to do nothing there in the exhaust line. So my question is, what does the factory exhaust system look like for my Saturn? Also, is there for any reason a screw that appears to do nothing? It is in the section of pipe that starts to go under the body of car from the engine compartment.
07/2018-PRESENT 1995 SL2
04/2009-04/2019 1994 SL1
Add to StrnWolf's Reputation
Rate the quality of this post and help StrnWolf reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
StrnWolf is offline   Reply With Quote
Old 08-10-2018, 07:38 AM   #2
Waiex191
Waiex191's Avatar
Default Re: What Does Factory Exhaust System Look Like?
My system is original. There are some incidental pictures in my thread, but not before page 7.
http://www.saturnfans.com/forums/sho...=230898&page=7
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 08-10-2018, 12:05 PM   #3
billr
billr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of light
Post a picture of that screw. If it isn't OEM, maybe we can think of a plausible explanation for it. My understanding is nothing other than the cat has to be OEM/CARB-exempted.
Add to billr's Reputation
Old 08-10-2018, 08:25 PM   #4
StrnWolf
1994 SL1
I will post a photo tomorrow, but for now I took a second look and it appears everything is where it should be. That is good news, but there is bad news. Looks like there may be some exhaust leaks because the connection points look very rust and very rugged, so not sure if there is a full seal. The CAT I know for sure is not original so I will be looking for the ID number when I go under car, also it is welded to the front pipe, so if I need a new CAT I need a new front pipe.
How would I check for leaks in the exhaust system?
Old 08-10-2018, 08:35 PM   #5
You should not replace the front pipe. A sawzall will remove the cat if required so a proper replacement can be welded into place.
Leak check.
--Locate a low pressure high volume air source, reversible vacuum cleaner, large fan, leaf blower or what ever you can find.
--Loosely couple to cold exhaust at the tail pipe, or direct fan at tail pipe.
--Spray every inch of the exhaust between the head and CAT outlet flange with a mixture of 2 or 3 drops of dish soap and water in a spray bottle.
--Pay close attention to the lower flange, lower support clamp, and flex connector.
--The flex connector is under the protective braid so it requires quite a bit of solution to show any leaks.
Old 08-10-2018, 11:57 PM   #6
StrnWolf
1994 SL1
Leak check.
I only have ONE device that may be able to do job, but I need confirmation if it would work then I can modify it to attach to tailpipe. It is a AC ball-bearing fan, please let me know if it would work...
Air Flow: 293.0 CFM (8.20m/min)
Static Pressure: 0.900 in H2O (224.2 Pa)
It has been sealed in a wood frame so should not be hard to attach a way to connect to tail pipe, would be thrilled to put it to use again after being boxed for over a year.
Old 08-11-2018, 08:49 AM   #7
That will work and you do not need a tight connection at the tail pipe as a couple inches of water pressure will show the leaks.
Old 08-11-2018, 09:16 AM   #8
laser3kw
laser3kw is on a distinguished road
2000 SC1
mine broke right in front of the flex pipe.
the replacement choices are limited. Most everything out there is "steel". Shop around and try and fine a stainless down pipe and cat.
Add to laser3kw's Reputation
Rate the quality of this post and help laser3kw reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
laser3kw is offline   Reply With Quote
Old 08-11-2018, 09:28 AM   #9
bumpdraft
bumpdraft's Avatar
1998 SW2
OP only has 0.9 of water pressure
Add to bumpdraft's Reputation
Old 08-11-2018, 06:33 PM   #10
That will work IF you use a bit of dish soap in the spray bottle and be observant for any trace of bubbles.
Old 08-11-2018, 10:40 PM   #11
StrnWolf
1994 SL1
Thank you all for your help! I am not able to do a leak test this month, so will have to do next. As soon as I do a test I will post the results, along with the mystery screw photo, but if I go under the car sooner I will be sure to take a photo of screw.
Where is the cheapest place to get an exhaust system? (downpipe, exhaust, everything) Major_Tom S-Series Tech 6 10-31-2010 10:50 AM
DVD System (Factory) paulstefano Outlook General 6 09-22-2007 10:21 PM
Installing amplified sub box to factory system ihdude Vue Mods 9 11-29-2006 09:16 AM
Factory sound system? My1stSUV Vue General 5 11-13-2004 02:05 AM
New sound system (adding a amp and sub to a factory system) QuadKewl Ion General 9 10-29-2004 04:03 AM
