Old 08-09-2018, 06:35 PM   #1
cgg17
cgg17 is just really nicecgg17 is just really nicecgg17 is just really nicecgg17 is just really nice
cgg17's Avatar
Default Computer fitment
Hello all,
I found a 95 sl1 manual computer. Will this run my manual swapped 1995 Sl2? The only side effects I can think of are lower rev limiters and speed limiters. Any other side effects? Both have manual windows, but mine has power door locks.
1994 Sl2 5spd: 56,576 (Totaled 1/10/2018)
1995 Sl2 5spd Manual Swap: 150,062
1999 Sl2 4spd: 98,8xx
Add to cgg17's Reputation
Rate the quality of this post and help cgg17 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 08-09-2018, 09:39 PM   #2
Default Re: Computer fitment
Yes but you will be happier with a DOHC 95 computer as the SOHC will initially try to run lean.
Old 08-09-2018, 10:52 PM   #3
cgg17
cgg17's Avatar
Running lean will damage my engine? Any way to adjust it manually? I dont plan on spending much, maybe $20 for it, so is it worth a shot? Or will it ruin my engine?
Old 08-10-2018, 12:51 AM   #4
Saturn Night
Running lean will burn the pistons and valves, over time, and cause power loses in addition to high NOx emissions. Get the correct PCM for a DOHC/Manual out of a 1995 Saturn S-Series.
OBD-I is NOT programmed like OBD-II systems of the 1996-2002 Saturn S-Series. And you can NOT manually reprogram OBD-I systems nearly as easily as an OBD-II PCM.
You'll spend about $300 on the software to hack the SOHC PCM, or you can snag a used PCM from a local wrecking yard.
1995 will only fit 1995, because of the digital EGR programming.
Old 08-10-2018, 06:08 PM   #5
cgg17
cgg17's Avatar
Thanks! Ill have to find a decent 95 dohc one.
Old 11-09-2018, 10:00 AM   #6
Using that logic, the '94 PCM from California Emission equipped car's would be the same. Not sure if anyone's tried it, might be worth testing if someone's bored and has spare parts that won't be much of a bother if they fry. I suspect the pinout or signal value change's from the mini size 1st gen gauge cluster to the normal size 2nd gen gauge cluster to be a far bigger issue.
Old 11-09-2018, 11:29 AM   #7
The CA pcm is rather rare and it is incompatible with most of the 95 wiring except maybe the EGR. The EGR module would work though but the PCM pinout is probably different.
Old 11-09-2018, 04:43 PM   #8
cgg17
cgg17's Avatar
It didn't work, the car would crank but not fire. I bought a 1995 Manual PCM for $40 on ebay two months ago for it (old thread). So, I can confirm that it does not work properly.
exhaust fitment laser3kw S-Series Tech 0 02-12-2016 09:08 PM
Headlight fitment carvinbassplyr Vue Red Line 4 08-10-2015 03:13 PM
EGR fitment AlexofNazareth S-Series Tech 7 08-01-2012 02:11 PM
radio fitment vtsl2 S-Series General 11 05-01-2012 02:35 AM
OEM header fitment 1993SC2 S-Series General 2 11-01-2004 11:12 AM
