Old 08-09-2018, 03:23 PM   #1
kimohands
kimohands has a spectacular aura aboutkimohands has a spectacular aura aboutkimohands has a spectacular aura about
Default Loud Clanking Noise Left Side Engine
I have a video to show the noise the car is making. 95 sl1, manual
Notice it when the car is at idle and under a load or if the rpms dip
It makes this noise constantly when the ac is on at idle.
Sounds like it is coming from the left side of the engine. I know i replaced the tensioner in 2016
New Timing chain last year
Otherwise it drives smooth.
https://youtu.be/pY8IAXXtIok
Mason in Florida
1995 Saturn SL1 SOHC 5Spd
Add to kimohands's Reputation
Rate the quality of this post and help kimohands reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kimohands is offline   Reply With Quote
Old 08-09-2018, 03:36 PM   #2
toggenburg
toggenburg's Avatar
Default Re: Loud Clanking Noise Left Side Engine
IS the sound just coming from the AC clutch while it is engaged?
I don't have access to sound here at work, so will view later at home, but it is presumed that when you say LEFT side of engine, you are referring to the passenger side when viewed while filming, not drivers side, correct?
It appears to shake a lot at idle, even tho you say it drives smooth, correct?
Old 08-09-2018, 04:03 PM   #3
kimohands
The sound can be heard when the ac is off mainly when something is adding load to the idling engine such as extra electrical load, however its pretty constant when the ac is on. The ac is on in the video.
Yes, passenger side, sorry.
Yes it drives smoothly but it is shaking a lot at idle. I believe all of the mounts have been replaced.
Mason in Florida
Old 08-09-2018, 10:20 PM   #4
billr
billr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of light
Disable each cylinder, one-at-a-time, by disconnecting the electrical cable to an injector; see if this can be pinned-down to a specific cylinder. Have you pulled the plugs to inspect them and take compression? Those basic checks may give some clues. Noises are notoriously hard to diagnose, especially from "long distance", but that sounds rather serious to me. Checking oil pressure with a gauge would be a good idea, too. Are you intent on saving this engine?
Add to billr's Reputation
Old 08-10-2018, 09:42 AM   #5
kimohands
Disabling cylinder 1 makes no difference (engine runs just as bad). Attached a pic of the plug.
Runs pretty smooth with one cylinder down, but at idle it sounds like crap.
Compression test is next on my list, not sure when i will get to it.
Mason in Florida
Old 08-10-2018, 12:13 PM   #6
billr
Clarify: Did you disable every cylinder one-by-one, or only one of them?
Old 08-10-2018, 12:33 PM   #7
kimohands
I disabled all of them one by one however cylinder one was the only one that didn't stumble the engine.
Mason in Florida
Old 08-10-2018, 03:16 PM   #8
billr
I wouldn't bother with anything else until the compression test results are in.
Old 08-14-2018, 02:28 PM   #9
kimohands
ok so #2,#3,#4 are all sitting around 170 and #1 is at 60. If i add some oil to #1 it jumps up to 120 for a round of testing then goes right back down to 60.
Mason in Florida
Old 08-14-2018, 04:17 PM   #10
Waiex191
Waiex191's Avatar
That is a classic bad ring/piston/cylinder symptom.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 08-14-2018, 04:38 PM   #11
kimohands
Ya, that's what i was thinking. Given the noise i imagine that cylinder is a mess. I guess i'll just swap out the engine (and peripherals). The junkyard up the road has like 4 96's. No 95's though.
Mason in Florida
Old 08-14-2018, 05:04 PM   #12
TomM96
The '96 blocks are Aluminum, otherwise close.
Add to TomM96's Reputation
Old 08-14-2018, 11:33 PM   #13
billr
Umm... all of the blocks are aluminum. The '96s will go easily into a '95.
Old 08-15-2018, 07:57 AM   #14
Only until a certain someone chimes in with his arm chair engineering degree and 0 knowledge beyond what the various GM posted interchange guides say.
'96-'98 heads will require a 2nd ECTS port drilled into the upper radiator hose outlet ($15 ish if you don't have the required 1/8" NPT tape and drill bit on hand), knock sensor plug may have changed (swap sensors...) and I believe everything else is good to go. Don't throw out the old engine & sensors until the 'new' one is in and working fine.
'99-'02 will be close to more work than most people want to do for a swap to '93-'98 but can also be made to work. If it's going into a '93-'98...your best bet is any '93-'98 engine. '91-'92 have fubar crankshafts rendering the blocks mostly incompatible with '93+ while '91 has a fubar engine mounting system.
clanking noise front left side ? jemstudio Vue General 1 07-12-2018 08:18 AM
Clanking noise from engine Glenn Ford S-Series Tech 4 11-23-2010 03:17 PM
Loud clanking metallic sound from PS of engine Glenn Ford S-Series Tech 6 05-18-2010 08:40 AM
Loud Clanking Noise + Horrible Rubber Smell. preythesun S-Series Tech 26 10-01-2009 06:58 PM
Loud flapping noise under right side, 20-50 MPH SLoneDC S-Series Tech 8 07-02-2007 04:08 PM
