Old 07-21-2018, 09:10 PM   #1
StrnWolf
StrnWolf has a spectacular aura aboutStrnWolf has a spectacular aura aboutStrnWolf has a spectacular aura about
1994 SL1
Default Coolant Temp Sensor vs Sender?
I did research and have not found a definitive answer on which one would be the ECTS that controls fuel/air mixture. On RockAuto there is a sender and a sensor for my 95 SL2. The sensor is identical to the air intake sensor and the sender is different. Which one controls the fuel/air mixture?
07/2018-PRESENT 1995 SL2
04/2009-04/2019 1994 SL1
Add to StrnWolf's Reputation
Rate the quality of this post and help StrnWolf reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
StrnWolf is offline   Reply With Quote
Old 07-21-2018, 09:44 PM   #2
billr
billr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of light
Default Re: Coolant Temp Sensor vs Sender?
The "sensor" is the one you need. SMP #TX73 or TX73T
Add to billr's Reputation
Old 07-21-2018, 10:51 PM   #3
StrnWolf
1994 SL1
Thanks! On a related, does the "sender" that controls the gauge also activate the radiator fan or does the ECTS activate the fan?
Old 07-22-2018, 12:34 AM   #4
billr
The PCM controls the fan, using the ECT sensor input. That 1-wire "sender" is only for the dash gauge.
Old 07-22-2018, 09:05 PM   #5
StrnWolf
1994 SL1
Thanks!
Coolant Temp Sensor? gr8gonzo0 S-Series Tech 2 05-12-2009 09:21 AM
coolant sensor vs. coolant sender funk53daba S-Series Tech 3 11-11-2008 06:02 PM
Coolant Sensor and temp sender 1994 Saturn xtra2b S-Series Tech 2 05-05-2008 04:24 PM
coolant temp sensor or what??? RMracing125 S-Series Tech 2 02-19-2007 07:31 AM
Does anyone now if the sensor on the transaxle is the same as the coolant temp sensor BigDaddyDrex1 S-Series General 4 05-27-2005 03:29 PM
