Old 07-21-2018, 06:41 PM   #1
Bruce Rock
2000 SL2
2006 VUE 2.2L
Default replacing the VSS on a manual Vue
To make a long story short, you may need a 12mm x 1.75 bolt 3" long screwed into the outer housing in order to extract the old sensor. I did not have to heat up the bolt to get better thread engagement, but that was a possibility if at first the bolt pulled out.
Before the bolt trick worked I was afraid I would have to drop the engine cradle to gain access. It can be seen from above, but on ramps I could only feel it from underneath.
Wife drove it around the block, speedometer gave steady readings.
I had pulled a sensor at a junk yard. It had abnormal wear particles on it as well as normal rubbing wear particles. If my sensor had metal particles on it I thought that might be affecting the readings. But my sensor was clean.
Add to Bruce Rock's Reputation
Rate the quality of this post and help Bruce Rock reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-19-2018, 05:23 PM   #2
Bruce Rock
2000 SL2
2006 VUE 2.2L
Default Re: replacing the VSS on a manual Vue
I just realized: The only reason my sensor was "clean" was because it came out in pieces. When the inner magnetic part came out any metal particles could have dropped of the outer sheath.
Old 10-23-2018, 07:55 AM   #3
prestone08
prestone08 is on a distinguished road
2006 VUE 2.2L
Hey!
I just did this about 3 times over thinking my sensor was my issue and it was a faulty ground wire. I picked up my sensor for like 30$ at autozone and it worked fine.
Add to prestone08's Reputation
Rate the quality of this post and help prestone08 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
prestone08 is offline   Reply With Quote
replacing mirror without replacing visor? jml L-Series General 2 07-19-2016 10:22 AM
Replacing Manual Transmission Shifter Cables waiter21 Vue Tech 0 04-10-2016 10:24 AM
Replacing power mirror with manual 2006 Vue 2.2 LostHillbilly Vue Tech 2 06-02-2014 10:43 AM
'99 Saturn S-series owner's manual or repair manual for sale sparhawk Classifieds 1 11-27-2005 03:35 AM
replacing front brake pads on 2002 L-200 requires replacing rotors? UserName L-Series General 12 12-29-2004 01:28 PM
