Old 07-21-2018, 07:31 AM   #1
Hiram_32
Hiram_32 is a glorious beacon of lightHiram_32 is a glorious beacon of lightHiram_32 is a glorious beacon of lightHiram_32 is a glorious beacon of lightHiram_32 is a glorious beacon of light
Default 02 SL2: Blue smoke when idling and low speed
For many months now, I've been noticing a lot of blue smoke billowing from the exhaust of my 02 SL2 after idling in traffic/parked and then shifting into drive. Someone recently told me this is caused by faulty rings in the engine--does anyone here have any insights/solutions?
156k Miles on engine
Thank you!
Last edited by Hiram_32; 07-21-2018 at 07:35 AM.. Reason: Forgot to specify year and model. =P
Add to Hiram_32's Reputation
Rate the quality of this post and help Hiram_32 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Hiram_32 is offline   Reply With Quote
Old 07-21-2018, 09:28 AM   #2
Waiex191
Waiex191's Avatar
Default Re: 02 SL2: Blue smoke when idling and low speed
Rings and/or valve guides. The oil control rings stick because there are no drain back holes in the pistons. Your best options, in my opinion, is to consider it as mosquito control, or rebuild the engine. I chose the latter.
http://www.saturnfans.com/forums/sho...d.php?t=230898
There are other threads out there, like cboss and ehunter.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 07-21-2018, 09:54 AM   #3
Saturn Night
Thank you!
Your valve stem seals are shot and the oil is leaking from the valve guides. You can do just the valve stems, without removing the head.
With the flaw in the pistons, you should probably plan on doing a full rebuild just to make sure that you don't have excess oil consumption with sticking rings. Sealed Power makes pistons with drain back holes drilled into them.
Old 07-22-2018, 01:38 PM   #4
Hiram_32
Thank you for the link, Waiex191. In your opinion, is there any danger of damaging the engine from prolonged use in this condition? I am about to do a road trip this week, and wondering there is any risk in doing so.
How long does a rebuild process take, approximately? 20hrs? Or more? Or less?
Old 07-22-2018, 01:39 PM   #5
Hiram_32
Saturn Night, thank you for the reply. If I comprehend correctly, you are suggesting that I can do the valve stems, and postpone a full rebuild until a later point?
Old 07-22-2018, 02:11 PM   #6
Waiex191
Waiex191's Avatar
No danger, just don't run low on oil. I'd say more than 20 hours, but I didn't keep track. My entire rebuild took 5 months including the gearbox, subframe, brake lines, headliner, and the hard part - replacing the instrument panel light bulbs.
Bryan Cotton
Dies When Idling and Black Smoke Deltree S-Series Tech 8 04-15-2013 08:18 PM
Blue Smoke or White Smoke...some defintions 2NDSOUT S-Series Tech 0 07-08-2009 10:16 AM
Blue Smoke??? Sprintst Vue Tech 8 03-08-2009 01:05 PM
Blue smoke? 123SVT S-Series Tech 5 11-27-2004 04:30 PM
Blue smoke Greenchrome93SL Miscellaneous Tech 18 06-02-2004 01:02 AM
