Old 07-20-2018, 02:18 PM   #1
craftsman70
craftsman70 is on a distinguished road
1998 SL1
Default Intake manifold air plenum
When I cleaned my throttle body on my 98 SL1 last week, I noticed it was pretty dirty in areas I couldn't get to, but was in a hurry. Specifically, the large aluminum part that the throttle body connects to looked pretty black/sotty were the PCV gases come in. I don't know the exact name for it, it might be intake manifold air plenum. When I search for the intake manifold I find pictures of the part which holds the fuel injectors. Is the intake manifold all one piece that goes directly from the throttle body to the engine block? Or does that top part come off for further cleaning?
Add to craftsman70's Reputation
Rate the quality of this post and help craftsman70 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
craftsman70 is offline   Reply With Quote
Old 07-20-2018, 02:24 PM   #2
Waiex191
Waiex191's Avatar
Default Re: Intake manifold air plenum
It is the manifold. The fuel injectors plug into the runners from the plenum. It is all one casting. Not super easy to remove but definitely possible.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 07-20-2018, 02:48 PM   #3
craftsman70
1998 SL1
Thanks. That definitely looks like I'd be opening a can of worms I'm sure its not fun trying to scrap and clean the surface on the back side of the engine for the intake manifold gasket. I think I'll take a 'if it ain't broke, don't fix it' approach. Thanks again for the picture of the full manifold.
Old 07-21-2018, 09:58 AM   #4
Saturn Night
Using an E6 inverted Torx socket can remove the studs for scraping the remaining bits of gasket off the surfaces of the head.
I wouldn't worry about the soot/carbon, unless you need to pull the cylinder head off the engine for a head gasket repair of other reason. The car will continue to run fine, despite all the soot inside the manifold.
2000 ls 3.0 v6, cant find part info for the intake plenum silicone hose? (6) demoncamber L-Series Tech 2 06-13-2014 03:38 PM
Intake Plenum/baffle ? dknight928 Vue Tech 7 01-18-2014 04:10 PM
Oil in intake Plenum lindann Vue General 4 09-20-2011 11:33 AM
WTB: 2000-2002 OE air intake and intake manifold Tycho Classifieds 0 03-03-2005 12:52 PM
Intake Plenum for 3.5Ltr VUE Tofer Vue General 0 05-01-2004 12:26 PM
