Old 07-19-2018, 08:37 PM   #1
dakota1820
dakota1820 will become famous soon enough
2002 SL
Default Front vibration when braking
Hey everybody as you know I just bought my 01 SL1 and when I bought it it had a very bad vibration upon hitting the brake pedal. I looked at the rotors when I took them off and you could definitely tell they were trash. So I put on brand new brake pads and rotors from AutoZone am I vibration is much better but still when I hit the brakes I get a vibration in the steering wheel. I did pull up the e-brake a little bit at speed to see how the rears by themselves felt and they were smooth. Is it possible I just got warped rotors out of the box or is there other things that maybe I should check? The suspension and wheel bearings were tight I had checked all of that while I had it in the air doing the brakes. Other than that the old girls running great new temperature sensor and spark plugs do wonders my wife rode in it who also owns a newer car and she was actually impressed with how well the Saturn did for its age. (My wife is a spoiled baby) so she would never say nice things about an average older car
Add to dakota1820's Reputation
Rate the quality of this post and help dakota1820 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dakota1820 is offline   Reply With Quote
Old 07-19-2018, 08:58 PM   #2
1996SW2
1996SW2 is on a distinguished road
Default Re: Front vibration when braking
Do you have a routine for bedding in new brakes and rotors?
Add to 1996SW2's Reputation
Rate the quality of this post and help 1996SW2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1996SW2 is offline   Reply With Quote
Old 07-19-2018, 09:38 PM   #3
dakota1820
2002 SL
Usually make half a dozen or so medium aggressive stops from about 60 down to 35mph.
Old 07-19-2018, 09:54 PM   #4
Waiex191
Waiex191 has a spectacular aura aboutWaiex191 has a spectacular aura about
Waiex191's Avatar
I'd recommend replacing the bushings and maybe the guide pins. Use the special silicone grease.
https://www.rockauto.com/en/parts/ac...r+bushing,1716
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 07-19-2018, 10:06 PM   #5
dakota1820
2002 SL
Why? They looked ok didn't see anything wrong with them I did replace the brake pad Hardware though.
Old 07-19-2018, 10:40 PM   #6
J.W.
J.W. is on a distinguished road
2001 SL2
You might check to be sure the rotors are fully up against the hub... Be sure there is no accumulation of rust or dirt etc 'behind' the rotor. Are the pads seated properly ?
Let us know what you find please...
JW
Add to J.W.'s Reputation
Rate the quality of this post and help J.W. reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
J.W. is offline   Reply With Quote
Old 07-19-2018, 10:49 PM   #7
dakota1820
2002 SL
I will double check and report what I find tomorrow. I know the pads are ok and the rotors just float in place but I'll make sure the hub looks clean I didn't notice anything out of the ordinary when I did them but I'll double check tomorrow.
Old 07-20-2018, 06:06 AM   #8
Waiex191
Waiex191's Avatar
I got away without replacing the boots and pins for a long time, and then I didn't. Apparently normal grease swells the rubber and causes the guide pins to bind. After replacing and using the silicone grease they slid much more freely.
Bryan Cotton
Old 07-20-2018, 06:57 AM   #9
toggenburg
toggenburg's Avatar
^^ Agreed, OP did not admit to cleaning and lubing the slide pins, which may be the source of vibration upon braking.
Old 07-20-2018, 08:10 AM   #10
floridasl22002
Check your tie rode ends for wear BOTH Outer and Inner. If an outer wears and you have movement, you will notice it as a vibration when you brake. Had that with a GM Olds some years. Felt like the wheels would fall off on braking.
Old 07-20-2018, 08:34 AM   #11
dakota1820
2002 SL
I did lube the slide pins, front end suspension was all tight. Anytime you do brakes you lube slide pins.
Old 07-21-2018, 09:52 PM   #12
dakota1820
2002 SL
So after using a dial indicator and checking both front rotors that were replaced I found that the passengers front was warped and I ordered a new one from AutoZone and they literally forgot to order it 5 times in a row so I finally got my money back and went to O'Reilly's and got a replacement rotor and it's fine now stops good and smooth.
2002 SC2 front end vibration when braking and when accelerating. StandsOnToes20 S-Series General 3 05-28-2013 10:10 PM
91 SL2 has bad front end vibration when braking chrisr123 S-Series Tech 3 09-23-2008 08:00 PM
serious vibration when braking VTVUE Vue General 27 08-07-2007 11:47 AM
Bad Vibration When Braking ricksLS1 Vue General 56 09-07-2005 07:35 PM
vibration on braking - Help 100KSW2 Miscellaneous Tech 4 12-18-2001 05:16 AM
