Old 07-19-2018, 09:32 AM   #1
Averjoe
Averjoe is on a distinguished road
Default Engine surging and stalling, engine temp gauge fluctuating, where do I start?
I have a 2002 SL2 with 240k. I've noticed for the past couple of weeks that the gas milage was about 5 mpg below normal. The battery died on me last week, so I replaced it, but the alternator seemed to be fine as it was showing around 14.5v at 2000rpm and about 13.8v under full load (lights, radio, wipers, defrost, etc)
However, yesterday the engine starts surging and almost stalling, and the engine temp gauge was fluctuating. Quick test showed alternator at less than 13v with no load. So, I replaced the alternator last night. This morning it starts doing the same thing on my way to work. It's throwing two codes, P0118 (expected) and P0714( not expected). After searching the forums, likely suspects are the ETCS, CPS, or the PCM. But, which should I try first?
Here's a video of what it's doing:
https://www.youtube.com/watch?v=KyQD...l=JosephPiazza
Add to Averjoe's Reputation
Rate the quality of this post and help Averjoe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Averjoe is offline   Reply With Quote
Old 07-19-2018, 09:46 AM   #2
ErikTande
ErikTande will become famous soon enough
ErikTande's Avatar
Default Re: Engine surging and stalling, engine temp gauge fluctuating, where do I start?
Do the coolant temp sensor first. That can cause those problems and the screwy gauge is a dead giveaway.
http://www.youtube.com/velocitylabs
Add to ErikTande's Reputation
Rate the quality of this post and help ErikTande reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ErikTande is offline   Reply With Quote
Old 07-19-2018, 09:49 AM   #3
ECTS, ECTS connector, ECTS wiring. No splices in the ECTS wiring unless soldered --NO crimp connectors!
Best guess is you have a bad crimp connector in the wiring and this alone will cause your symptoms.
Old 07-19-2018, 03:25 PM   #4
Averjoe
Thanks guys. After a few minutes rooting around, I found that one of the wires to the ECTS was bad. Luckily, I found a replacement connector locally, just have to wire it up tonight. Time to break out the soldering iron and heat shrink. I think I may also get some wire loom to better protect it.
2003 Vue Engine Temp Gauge flatline n8wudz Vue Tech 3 09-17-2009 04:30 PM
Engine Temp Gauge Doesn't Work ExMiata S-Series General 20 01-27-2008 06:26 PM
Normal Engine Temp Gauge?????? So.CalifsJnRe24 S-Series Tech 4 12-22-2005 09:07 AM
Temp Gauge drops and engine RPM rises devinr S-Series Tech 5 05-10-2005 02:11 PM
Engine Cooling Fan and Temp Gauge Mike H S-Series General 1 03-18-2004 01:45 PM
