Old 07-18-2018, 04:27 PM   #1
cuetip
cuetip is just really nicecuetip is just really nicecuetip is just really nicecuetip is just really nicecuetip is just really nice
1997 SW1
Default Outer Tie Rod End Brand?
I'm going to be replacing the power steering rack in my '97 SW1. I figured I'd replace the outer tie rod ends too since the ones installed now are old. Which brand should I go with? I hear Moog is good. What about ACDelco's professional series?
I noticed that the cotter pin on both tie rod ends don't go through the castle nut slots. Why is this? Tightened too far? Bad part? This will be my first time doing this job.
Add to cuetip's Reputation
Rate the quality of this post and help cuetip reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cuetip is offline   Reply With Quote
Old 07-18-2018, 04:33 PM   #2
BV22
2002 SC1
Default Re: Outer Tie Rod End Brand?
I've always had good success with Moog suspension parts, and used their outer tie rod ends on my Saturn. Something is wrong in that picture. Either the wrong tie rod end, the wrong nut or a badly worn hole in the steering knuckle. Cotter pin should engage through the cut outs in the nut.
BV22
2002 SC1 5M
RIP Sept 1 2018
315,344 miles
Add to BV22's Reputation
Outer Tie Rod Ends hydromech S-Series Tech 4 03-12-2012 02:57 PM
inner or outer tie rod? 10Miler S-Series Tech 5 09-28-2011 05:02 PM
Outer Tie Rod Jam Nut jpleech S-Series Tech 6 01-10-2011 10:23 AM
outer tie rod end question Bigbadbert S-Series Tech 5 03-02-2005 01:58 AM
