Old 07-18-2018, 09:38 AM   #1
DonP1
DonP1 has a spectacular aura aboutDonP1 has a spectacular aura aboutDonP1 has a spectacular aura about
Default Do SC's have more road noise than
An SL? Just wondering.
My 1999 SC2 auto seems like the rear trunk area is designed like a megaphone amplifying noise into the cabin. The rear speakers seem louder than the fronts as well. This is the only SC I've had.
I've had 4 SL2's and they seem quieter.
The tires on the SC2 are new Douglas $40 ones from Walmart, although the replaced Michelin tires seemed just as noisy. When I bought the car I thought it had bad wheel bearings, but it is just road noise.
The car drives great, I'm getting about 32mpg, and it has 144K on the clock. Brakes are all new (rotors drums replaced).
Add to DonP1's Reputation
Rate the quality of this post and help DonP1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DonP1 is offline   Reply With Quote
Old 07-18-2018, 03:10 PM   #2
hholbein
1997 SW2
Default Re: Do SC's have more road noise than
Certainly the stock SWs are also fairly noisy from the open cargo area back there -- perhaps more than the SCs
About 10 years ago I applied an adhesive Dynamat type sound deadening to the entire cargo area, rear wheel wells, and outer door panels. It did help a lot and wasn't all that hard or expensive to do.
It's still nowhere near as quiet as the Avalon we have, but it's acceptable.
Add to hholbein's Reputation
Old 07-18-2018, 04:54 PM   #3
Waiex191
Waiex191's Avatar
Mine is loud. Does not help that the soundproofing has been stripped out of the doors, or that half the door mount tabs have busted off.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 07-18-2018, 07:41 PM   #4
dummo
dummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of light
dummo's Avatar
1997 SW2
Where do you get this adhesive type Dynamat material that you speak of?
Tell us.
1994 SL1 new traded
1992 SL2 new traded for above
Add to dummo's Reputation
Old 07-19-2018, 09:02 AM   #5
DonP1
FYI, I drove my 2001 SL2 in to work today. Much quieter.
Old 07-19-2018, 09:26 AM   #6
ErikTande
ErikTande will become famous soon enough
ErikTande's Avatar
Tell us.
I use Peel n Seal from Lowes. Works awesome.
http://i63.tinypic.com/2qbzqed.jpg
I also put reflectix down which really helps keep things cool. Probably helps with road noise a little too.
http://i63.tinypic.com/14cxv79.jpg
http://www.youtube.com/velocitylabs
Add to ErikTande's Reputation
Rate the quality of this post and help ErikTande reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ErikTande is offline   Reply With Quote
Old 07-19-2018, 01:03 PM   #7
Macgyver
I've never noticed a difference. I can tell you 1st gen S series are louder than the 2nd/3rd gen's. The sound deadening added around the firewall really helped quiet things down.
Add to Macgyver's Reputation
Old 07-19-2018, 07:47 PM   #8
hholbein
1997 SW2
Here's the link to the sound deadening post from 7 years ago.
The sound deadening stuff came from http://www.raamaudio.com/
http://www.saturnfans.com/forums/sho...ight=deadening
Road Noise grendel5269 Vue General 4 01-13-2015 04:32 PM
Road Noise Magnum3672 Vue Mods 6 04-14-2012 01:05 PM
Front end noise/road noise Graham052 Ion Tech 5 09-04-2010 01:29 PM
Road Noise juleepet Vue General 3 10-08-2007 04:18 PM
road noise in SC2 SexyMexi02SC2 S-Series General 7 11-17-2003 01:32 AM
