Old 07-16-2018, 11:29 PM   #1
nkb97sl1
nkb97sl1 is on a distinguished road
Dizzy HELP! Accidentally pulled the purple horn wire out while trying to remove steering wh
We have a 1997 SL1 that is on 188k miles. My husband's ignition switch went bad (after a few weeks of intermittent no key dinging) and started to smoke. He drove it home and we realized the switch went bad. We ordered a new one and watched the richpin video and removed the airbag and then tried to remove the steering wheel. It didn't mention unhooking the horn button so we didn't and when my husband was able to finally get it off, he ripped out the purple wire going to the airbag coil and the black wire to the right hand horn button.
Is there anyway to fix this or are we screwed? We need the horn to work for inspection that is due at the ends of this month.
After further research I realized I didn't even need to take the steering wheel off which is like adding salt to the wound.
Any help is greatly appreciated!
Thanks
Add to nkb97sl1's Reputation
Rate the quality of this post and help nkb97sl1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nkb97sl1 is offline   Reply With Quote
Old 07-17-2018, 06:53 AM   #2
Waiex191
Waiex191's Avatar
Default Re: HELP! Accidentally pulled the purple horn wire out while trying to remove steerin
There is a Richpin video on horn button replacement. It is easy once the airbag is off. Undo the connector, unscrew the ground, and the buttons slide right out. I have a cracked horn button I need to replace. I yanked one from the junkyard.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 07-17-2018, 07:01 AM   #3
nkb97sl1
Thanks
Thank you for responding,
I maybe didn't explain it clearly. We didn't disconnect the horn connector, so the purple wire ripped our of the airbag clockspin. Not sure how to get the wire attached again with the other three wires.
Old 07-17-2018, 05:11 PM   #4
Macgyver
Pictures will help here. We need to see the damage.
Add to Macgyver's Reputation
Old 07-17-2018, 09:17 PM   #5
nkb97sl1
Here is a picture of 1) the wire pulled out and 2) where it was pulled out of.
I tried to push it back into the connector but now the horn isn't working. I was able to replace the ignition switch without removing any other part of the steering column (ugh if only I had discovered that earlier) and put it all back together so my husband could drive to work tomorrow
We need the horn to work to pass inspection. (Must be done in the next two weeks. ) Should I try to fox ir in the wheel or explore and auxillary horn (was suggested to me at the auto parts store today)
Thank you for any help!
Old 07-18-2018, 09:23 AM   #6
trottida
trottida's Avatar
You would need to solder the connection of the wire to the pin in the connector. I believe the pin comes out like most automotive connectors; it has a locking tab that you would need to depress to release it.
The other option is to find a donor car and cut the connector off with a few inches of leading wire or several depending where you decide to splice. You would then splice the donor connector into your cars wiring replacing the damaged connector. It's best to solder and shrink wrap each wire to ensure a good connection.
2001 SL1 MT (428,500 km @ 01/2019)
1999 SL2 MT (272,500 km @ 01/2019)
2011 Suburban LT (120,506 km @ 01/2019)
Past Saturns
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 07-18-2018, 01:18 PM   #7
Macgyver
Yes, what trottida says. Remove the connector and inspect the connection. There is way to remove the wire pin. From there, you can resolder the wire onto the pin and then push the pin back into the connector.
Or go to the junkyard and cut this connector off a donor vehicle. You'd then resolder the 5 wires with the connector attached onto your car.
Old 07-20-2018, 12:59 PM   #8
nkb97sl1
Thanks great news! My only question is I can't seem to get the connector off of the clockspring? Is there a trick I am missing?
Thanks!
Old 07-20-2018, 02:38 PM   #9
trottida
trottida's Avatar
It's been a while since I've looked at one but now I'm thinking that you'll have to replace the clock spring. Where do the other wires coming from the damaged area go to? Connectors that plug into the wiring harness or the wiring harness itself?
Without seeing the whole picture I made an assumption it was the later. If not then I think you'll have to replace the clock spring.
I have one in storage; I'll see if I can remember to take a look at it this evening.
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 07-24-2018, 04:54 PM   #10
nkb97sl1
Thanks for your insight.
The connector is attached to the clockspring which is why I'm hesitant to try to disconnect it. The damaged purple wrire is to the horn the other wires I believe deal with the airbag but are in the connector and not affected, so I don't want to mess with it too much.
We were told to buy this to pass inspection with a horn
https://shop.advanceautoparts.com/p/...B&gclsrc=aw.ds
Old 07-28-2018, 03:52 PM   #11
nkb97sl1
Thank you for all your advice. After peeling back plastic on the wire I was able to shove it in far enough to get the horn working again!
Love this group. ...you keep our saturn going!
Old 07-28-2018, 04:51 PM   #12
toggenburg
toggenburg's Avatar
Glad you got it going again, perseverance works!
Oh, I don't know which state you live in, but I doubt Virginia would pass a car that did not have the horn button on the steering wheel, but used a dash mounted button.....
Purple horn wire accidentally ripped out when removing steering wheel. HELP nkb97sl1 L-Series Tech 2 07-16-2018 11:30 PM
How to correctly wire 12v 40amp relay for air horn system from 3 wire horn connector? demoncamber S-Series Mods 2 06-20-2013 01:44 PM
Long axle shaft accidentally pulled and transmission fluid poured out JojoTheGreat S-Series Tech 4 06-13-2012 12:23 AM
Jump the starter with, the purple wire??? ghostcyber S-Series Tech 4 09-16-2010 12:05 AM
purple wire Donnyf General Saturn Discussion 8 11-14-2007 10:15 PM
