Old 07-16-2018, 11:20 PM   #1
nkb97sl1
nkb97sl1 is on a distinguished road
Dizzy Purple horn wire accidentally ripped out when removing steering wheel. HELP
We have a 1997 SL1 that is on 188k miles. My husband's ignition switch went bad (after a few weeks of intermittent no key dinging) and started to smoke. He drove it home and we realized the switch went bad. We ordered a new one and watched the richpin video and removed the airbag and then tried to remove the steering wheel. It didn't mention unhooking the horn button so we didn't and when my husband was able to finally get it off, he ripped out the purple wire going to the airbag coil and the black wire to the right hand horn button.
Is there anyway to fix this or are we screwed? We need the horn to work for inspection that is due at the ends of this month.
After further research I realized I didn't even need to take the steering wheel off which is like adding salt to the wound.
Any help is greatly appreciated!
Thanks
Add to nkb97sl1's Reputation
Rate the quality of this post and help nkb97sl1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nkb97sl1 is offline   Reply With Quote
Old 07-16-2018, 11:24 PM   #2
02 LW300
02 LW300 is just really nice02 LW300 is just really nice02 LW300 is just really nice02 LW300 is just really nice
02 LW300's Avatar
2002 L-Series 2.2L Sedan
Default Re: Purple horn wire accidentally ripped out when removing steering wheel. HELP
You probably should post this in the S series forum, I think I have only driven one S series car.
2002 L200/5 loaded, loving my stick shift car now with KYB struts and adjustable rear control arms.
Add to 02 LW300's Reputation
Old 07-16-2018, 11:30 PM   #3
nkb97sl1
Thank you so much, in my panic I selected L series instead of s
How to correctly wire 12v 40amp relay for air horn system from 3 wire horn connector? demoncamber S-Series Mods 2 06-20-2013 01:44 PM
Horn/Steering Wheel Fenblack S-Series Tech 3 04-19-2012 04:29 PM
Removing steering wheel nauticalstar S-Series Tech 3 05-09-2011 10:39 PM
Removing steering wheel/horn tallNewfie Astra Tech 1 12-30-2009 02:59 PM
Cruise and Horn do not work on Steering wheel..need help dschwer S-Series General 5 03-03-2006 12:07 PM
