Old 07-16-2018, 10:44 PM   #1
rkert99
rkert99 has a spectacular aura aboutrkert99 has a spectacular aura aboutrkert99 has a spectacular aura about
Default TPMS learning mode.
I bought a set of aftermarket wheels for my Astra so I need to reset the TPMS. I have one of the tools to do that but i can't get the car to go into learning mode. I followed what I thought was the correct procedure. Turn the ignition to the on position but don't start the car and then press the lock and unlock buttons on the key fob simultaneously. But nothing is happening. Is there a different procedure for the Astra or for a manual car?
rkert99 is offline   Reply With Quote
Old 07-17-2018, 07:05 PM   #2
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
Default Re: TPMS learning mode.
Not sure but astra does not use gm tpms system. Think that procedure is for gm cars. Thinking maybe you need a tool .
Old 07-17-2018, 07:37 PM   #3
nicolas_p
nicolas_p has a spectacular aura aboutnicolas_p has a spectacular aura about
nicolas_p's Avatar
2009 Astra XR
2008 Astra XE
There is no tool required. As long as you bought the correct tpms sensors the car will self learn the sensors while driving above 15mph for a couple miles. The astra uses a passive sensor system where the car monitors the pressure but not at a specific tire, it won't tell you which tire is low just that there is low pressure.
09 Vauxhall Astra XR3/STD
18" Team Dynamic MonzaR rims
Eibach Sportline, Whiteline BHR75Z swaybar and EBC Rotors
CD30 Mp3, Insignia jets, vxR surround, sharkfin antenna, Spoiler, Tint
nicolas_p is offline   Reply With Quote
Old 10-24-2019, 12:27 PM   #4
machinn
machinn has a spectacular aura aboutmachinn has a spectacular aura aboutmachinn has a spectacular aura about
Did anyone manage to figure out how to reset the TPMS in case the Saturn Astra does not auto reset? I am just tired to look at the yellow sensor light on the dash. Thanks!
machinn is offline   Reply With Quote
Old 10-24-2019, 01:26 PM   #5
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
Based on this....It auto resets
http://www.saturnfans.com/forums/sho...60&postcount=7
Old 10-24-2019, 06:50 PM   #6
nicolas_p
nicolas_p's Avatar
2009 Astra XR
2008 Astra XE
It auto resets, chances are that you have a dead TPMS sensor. I've already replaced all of mine when the batteries failed 3 years ago
Old 10-24-2019, 09:30 PM   #7
machinn
Thanks for the advice! But I never had any issue with the sensor, before changing two tires in the front and moving the best remaining two in the back. It this is indeed the case, I guess I will have to wait until I change the other two tires to replace all sensors.
Old 10-25-2019, 05:00 PM   #8
Is there info in the owner's manual on life expectancy of tpms batteries. General info says no more than ten years but recommendations are to replace sensors when replacing tires. Calculation of tire life in years can determine when to replace sensors to maximize their use while avoiding dead batteries and adding costs to sensor replacement from needlessly dismounting a tire for sensor replacement.
Old 10-26-2019, 03:55 PM   #9
imaddicted2u
2008 AURA XE
Based on this...it seems a possibility could be that one or both of the sensors were damaged or removed and replaced with new valve stems. Also, moving a sensor with a weak battery farther from the receiver could cause this sort of issue. A tire shop might be able to use their TPMS tool to communicate with each sensor and read battery level.
Old 10-26-2019, 04:12 PM   #10
imaddicted2u
2008 AURA XE
This video explains checking Tire Pressure Monitoring System (TPMS) Battery Information
https://www.youtube.com/watch?v=KwYLlh1PQu4
NEWBIE here again- still learning GPCBAKER S-Series Tech 8 06-09-2011 06:13 PM
High speed wiper mode active when in Retained Accessory Power mode MJD112379 Aura General 15 07-25-2008 07:24 PM
Learning about cars... Serpico General Saturn Discussion 2 06-25-2007 02:23 PM
The learning curve... The Critic S-Series Tech 6 10-18-2006 05:08 AM
Learning karinhesed86 General Saturn Discussion 3 02-01-2006 08:25 PM
