Old 07-15-2018, 09:40 PM   #1
jlangille
jlangille is on a distinguished road
Default Help with stalling and shaking
Help...
2002 Saturn SL1
I was sitting at a red light today and my car started to sputter and then stall out. I started it again but had to give it a fair amount of gas to get it going and just barely got it off the road. The engine sputter while running and only stays going if I give it some gas, there is also a clicking sound. I'll try to post a video..
Any ideas?
Add to jlangille's Reputation
Rate the quality of this post and help jlangille reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jlangille is offline   Reply With Quote
Old 07-15-2018, 09:58 PM   #2
jlangille
Default Re: Help with stalling and shaking
I tried to add a youtube link but I can't because I don't have fifteen posts on the forum...search 2002 Saturn sl1.. help please on youtube
or pm me for the link.
Old 07-15-2018, 10:07 PM   #3
Cheyne
2000 SL2
Did the service engine soon light illuminate? First thought is EGR and I just read earlier posts where you were having problems with it before.
Add to Cheyne's Reputation
Old 07-15-2018, 10:15 PM   #4
jlangille
I had replaced the EGR valve a while back and have not had the EGR code for 3 or so months now.
No check engine codes at the time of the incident but have some now..
P0410: Secondary Air System
P0506: IAC system too low
P1599: Engine Stall Detected
I had the secondary air system a couple months back but took off the secondary air passage and cleaned it which seemed to resolve the issue.
I did run to the junkyard and threw an Idle Air Control valve at it as it is listed as a possibility for both codes. no luck.
The clicking sounds metal to metal which wouldn't be good. Really unfortunate that I can't post a link to the vid.
Old 07-15-2018, 10:33 PM   #5
Waiex191
Waiex191's Avatar
Here is the link:
https://youtu.be/Y17qdCEdkYY
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 07-15-2018, 11:14 PM   #6
jlangille
Pulled the valve cover off.... having trouble uploading the picture.... but it looks to be a Rod. Darn.
Old 07-16-2018, 12:20 AM   #7
jlangille
Correction.. broken spring. Every else appears like it might be Ok. Trip to pick and pull tomorrow and I'll hope for the best haha.
2008 Vue Hybrid Stalling/Shaking, and making Popcorn noises at startup. HalifaxHybrid Vue Green Line 18 10-02-2008 11:44 AM
Shaking Timguy1008 S-Series Tech 1 06-17-2008 10:25 AM
shaking Timma L-Series General 3 03-13-2005 09:37 PM
Bad shaking Bigbadbert Miscellaneous Tech 4 12-21-2003 01:09 AM
bad shaking dazz_sc1 S-Series Tech 4 04-15-2003 12:18 PM
