Old 07-15-2018, 07:08 PM   #1
hydromech
hydromech is on a distinguished road
hydromech's Avatar
Default AC clutch engaging. No cold air
Refrigerant level was so low that AC clutch could not engage. I hooked my AC recharge kit and added one can of 134a. I did that every other season and so far AC was functioning.
This time - after adding 134a, AC clutch is engaging OK, kit pressure gauge reads OK pressure.
But still - no cold air produced..
HOT Chicago summer what can be done ?
2000 Saturn SL1, SOHC, Automatic, 189K
Add to hydromech's Reputation
Rate the quality of this post and help hydromech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hydromech is offline   Reply With Quote
Old 07-15-2018, 07:33 PM   #2
RobertGary1
Default Re: AC clutch engaging. No cold air
You need to put a set of gauges on it.
-Robert
RobertGary1 is online now   Reply With Quote
Old 07-15-2018, 07:42 PM   #3
hydromech
hydromech's Avatar
Thanks for reply
set of gauges will show if Compressor is OK ?
Clutch is engaging. That means there is enough pressure to keep pressure switch closed... Why - no cold air ???
Old 07-15-2018, 08:53 PM   #4
toggenburg
toggenburg's Avatar
Most likely, you are compressing 1 can of R134a and an equal amount of AIR.
Need to pull a vacuum, prove it stays a vacuum and then recharge while monitoring both the High (gas) side gauge, and the Low (liquid/suction) side gauge set.
Old 07-15-2018, 10:02 PM   #5
hydromech
hydromech's Avatar
I wonder - how could air get into the AC system. I never disconnected any AC component or hose. And there was some pressure left before I put my 134a into the system...
I only have a hand vacum pump. That one is not strong enough to evacuate ?
Old 07-15-2018, 10:07 PM   #6
toggenburg
toggenburg's Avatar
You added refrigerant because your system was not full, correct?
Well, it had leaked out somewhere (maybe even the low side port's o-ring) so whenever the AC was turned on, the low side (remember, that is the suction side of the system) begins to draw and since there had been a refrigerant leak somewhere, i'd bet that the suction line simply pulls in AIR through the damaged/compromised leaking area.
Use a UV light and you should find the leak source
Old 07-16-2018, 12:15 AM   #7
Originally Posted by hydromech View Post
Refrigerant level was so low that AC clutch could not engage. I hooked my AC recharge kit and added one can of 134a. I did that every other season and so far AC was functioning. This time - after adding 134a, AC clutch is engaging OK, kit pressure gauge reads OK pressure.
But still - no cold air produced..... HOT Chicago summer what can be done ?
How much was spent over the years? Since you know this system leaked, an inexpensive uv light and time spent searching for the elusive leak could have revealed where it occurred then determine what's needed to repair it once, permanently to restore factory cooling without refilling every year. Even the service valves leak after so many years of repeated use. HINT: if service valves bubble up then the valves are leaking and maybe the main source of at least one leak. Caps will not seal against leaks by themselves. Since you have no idea why cooling didn't return, you also have no idea how much refrigerant leaked - all of it, most of it, to conclude no cooling this time. If I recall correctly, 24 ozs or 1 & 1/2 lbs of r134a is required. There are no gauges to tell anyone how much was lost or how much to fill. Expertise in vehicle refrigeration can determine it but only when refrigeration gauges are used and for the S-series, 2k rpm while monitoring pressures and ambient temperatures/humidity.
BTW, if you use refrigeration gauges, unless you're aware, anyone unfamiliar with proper operation of gauges may introduce air and moisture into a system as soon as hoses are connected. Every hose and gauge set are open to the atmosphere so connecting hoses and gauges automatically becomes pressurized (presuming some refrigerant is still in a system). As soon as ac is turned on, compressor running, air and moisture are immediately drawn into the system from gauges/hoses unless they're purged before ac is turned on. Purging lines and gauges are part of advanced refrigeration procedures otherwise contaminating a system with air and moisture will occur.
A/C compressor engaging but no longer blowing cold. allstar21369 S-Series Tech 3 06-16-2016 05:31 PM
No A/C, clutch not engaging tk3000 S-Series General 3 06-16-2012 06:16 PM
Having issues with clutch engaging kyles01sl2 S-Series Tech 7 11-28-2011 09:56 PM
A/C Clutch Not Engaging AmiesLivin4Him S-Series Tech 3 05-20-2008 05:13 PM
LS1 clutch not engaging gdr L-Series General 3 05-06-2006 07:43 AM
