Old 07-15-2018, 03:39 PM   #1
nwhipkey2
nwhipkey2 is on a distinguished road
Default High Idle/Low Efficiency Codes
I recently have swapped a dohc in my 98 sl1, and have been trying to work out all the kinks to get the car ready for an e-check. The donor motor has 160k but runs strong besides a few minor hiccups. The car will run perfectly fine except for in idle, where it jumps to 1800-1900 rpm when put in neutral, and shows no sign of going down, even after 30+ minutes of running. The codes that the computer is providing are P0507 (idle), P0420 (cat sensor?), and P0134 (sensor again?).
I have already replaced the egr and tried to get the idle to drop or at least vary by spraying brake cleaner around the intake manifold as well as restricting the throttle body with my hand. The actual throttle plate sticks a bit and I will have to remove and clean to make sure that it isn't the issue. If it isn't, would it likely be a faulty IACV or something else?
As for the other 2 codes, I have not yet replaced the piping after the cat and suspect that due to no resonator the gases are getting restricted and throwing off the 02 sensor. I have already purchased the resonator as I figured it would be required for the swap but just wanted to get the vehicle home. If there is likely some other reason that I'm unaware of please comment, as I just wish to get this thing crisp and clean for its inspection. Thanks for the input!
Add to nwhipkey2's Reputation
Rate the quality of this post and help nwhipkey2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nwhipkey2 is offline   Reply With Quote
Old 07-17-2018, 05:30 PM   #2
nwhipkey2
Default Re: High Idle/Low Efficiency Codes
Idle caused by intake manifold gasket, as for the low efficiency codes for bank 1 02 sensors, I will not know if they are resolved until after changing the gasket. If anyone knows anything about these codes and could give insight I would greatly appreciate the help.
Old 07-18-2018, 02:45 PM   #3
BV22
2002 SC1
P0134 is no activity from front sensor. It is either not connected correctly or bad. I'd fix that before worrying about the P0420 code, since a working front sensor is likely required for the cat efficiency check to work right.
BV22
2002 SC1 5M
RIP Sept 1 2018
315,344 miles
Add to BV22's Reputation
Old 07-22-2018, 06:17 AM   #4
nwhipkey2
Finally got the idle to drop down to about 900-1000 which feels much nicer now, although I think that once I replace the throttle body vacuum line it might drop another 50-100, but don't know for sure. SES and SE lights still on, will have to check if the idle code persisted.
Old 07-22-2018, 03:53 PM   #5
nwhipkey2
Can't get a single code to show on any OBDII reader, but SE light is still on. I haven't been able to drive it more than about 10 minutes at a time since the codes have gone away, so is this most likely just a check that will automatically turn off when the PCM believes the problem has been fixed for long enough?
Old 07-22-2018, 07:30 PM   #6
Check for a blown 10 amp BODY fuse. Examine the OBD II ports wiring. Pin-16 is power to the port while the other three wires are signals.
2002 SL1; high idle, codes 507, 301 nxne75 S-Series Tech 6 10-28-2016 02:21 AM
94 SL1 High Idle with codes 13 and 32 Scouser S-Series Tech 4 08-01-2016 10:59 PM
2006 2.4L High Idle no codes willyok Ion General 9 07-21-2015 01:42 AM
SL1 2002 High Idle w/ SES codes SL1Queen S-Series Tech 1 06-12-2011 11:36 PM
1997 SL High Idle, EGR DTC codes king_tim S-Series Tech 12 11-06-2008 02:44 PM
