Old 07-10-2018, 02:05 AM   #1
sc2 saturn
sc2 saturn is on a distinguished road
Default passenger side tire wear inside
when i was working on car had car jacked up and of course jack slipped out and bent trailing arm so i re bent it back to where its so close to straight again anyways noticed tire on the bent trailing arm side ( passenger side) i have tire wear on inside of tire i was reading that rear suspension is adjustable by adjusting the latterial arms is it true on the 01 saturn sc2? or could it possible be bushings that need to be replaced car has almost 210k on it nothing is aftermarket on the car for suspension wise everything is OEM
Add to sc2 saturn's Reputation
Rate the quality of this post and help sc2 saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sc2 saturn is offline   Reply With Quote
Old 07-10-2018, 02:51 AM   #2
Default Re: passenger side tire wear inside
I think you're describing a camber problem. Adjustment is as shown, from the service manual.
Old 07-11-2018, 04:38 PM   #3
Highmile
Highmile's Avatar
Those arms will be somewhat weak if they've been bent and I'd recommend replacing the bent arm.
Either way you need an alignment. Even know what to adjust is just guessing unless you have the machine to put it on
Highmile
'95 SL1 662k and counting
Add to Highmile's Reputation
Rubber burn smell near the Passenger Side Tire pepin Aura General 8 02-14-2013 01:19 PM
Passenger side door is not opening from inside or out matra Vue Green Line 1 01-19-2011 10:54 PM
passenger side tire rubbing during hard braking carfleet mntc S-Series Tech 4 12-04-2010 12:12 AM
Inside tire wear on rear? keautocenter S-Series Tech 24 07-27-2009 10:32 AM
Fluid under the passenger side rear tire Red97sc2 S-Series Tech 15 04-16-2005 10:05 PM
