Old 07-09-2018, 06:56 PM   #1
odiaz1831
odiaz1831 is on a distinguished road
2003 ION-3 Sedan
Default Input Shaft Nut
Guessing getting a replacement is pretty much impossible now? Saw one guy on ebay asking around 150 for it...Heard you can reused the same one and tighten to 132lbs? Using scotchweld threadlocker? Also would you recommend doing valvebody replacement or input shaft nut tightening first?
Add to odiaz1831's Reputation
Rate the quality of this post and help odiaz1831 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
odiaz1831 is offline   Reply With Quote
Old 07-09-2018, 07:07 PM   #2
red92xblue
red92xblue is on a distinguished road
red92xblue's Avatar
Default Re: Input Shaft Nut
I used red thread locker loctite and reused the same nut. That was 70k miles ago on a rebuilt trans. I read that the valve body goes bad (Banging) causing the nut to come loose.
Add to red92xblue's Reputation
Rate the quality of this post and help red92xblue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
red92xblue is offline   Reply With Quote
Old 07-09-2018, 07:13 PM   #3
odiaz1831
2003 ION-3 Sedan
Yah, kinda worried about being able to reuse it though. My SIL got this car 90k miles doing the reverse slam. Handed it over to me with 136k on the dash still doing the reverse slam... They didnt even attempt to fix it. So not sure the quality of that nut at this point
Old 07-09-2018, 10:24 PM   #4
Macgyver
Macgyver is a glorious beacon of lightMacgyver is a glorious beacon of lightMacgyver is a glorious beacon of lightMacgyver is a glorious beacon of lightMacgyver is a glorious beacon of lightMacgyver is a glorious beacon of light
I feel like a machinist could make a batch somewhere, someway. These aren't high tech things here.
Add to Macgyver's Reputation
Old 07-10-2018, 11:18 AM   #5
colonelhogan44
colonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nice
colonelhogan44's Avatar
I wouldn't be opposed to making a small run of these given enough demand. We've all discussed this before and there was no interest to this point.
MechE - I make things!
EGR ADAPTERS AVAILABLE! $30 "reverse" $40 standard
1998 SL2 (gone, never forgotten)
2005 Volvo S40 T5 AWD
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Add to colonelhogan44's Reputation
Rate the quality of this post and help colonelhogan44 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
colonelhogan44 is offline   Reply With Quote
Old 07-10-2018, 11:44 AM   #6
It is a standard aircraft part. All you need to start finding them is the diameter and pitch so it can be looked up.
Old 07-10-2018, 12:01 PM   #7
Waiex191
Waiex191's Avatar
It's not metric?
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 07-10-2018, 12:24 PM   #8
odiaz1831
2003 ION-3 Sedan
I know I'd get one, but id only need one or two at most. Kinda ballpark question here now, who can make an aluminum intake manifold to replace the plastic one on the Saturn 🤔
Old 07-10-2018, 12:40 PM   #9
toggenburg
toggenburg's Avatar
That's a huge block of aluminum to CNC mill down to make just one,let alone cast one.
Pick n pull is your best bet, decent ones are there for the picking.
OR, repair it (watch)
https://www.youtube.com/watch?v=cy2ztwi8Tao
Old 07-10-2018, 03:56 PM   #10
It is a steel nut, probably forged.
Old 07-10-2018, 03:57 PM   #11
Originally Posted by Waiex191 View Post
It's not metric?
yes, it is metric.
Old 07-10-2018, 04:34 PM   #12
toggenburg
toggenburg's Avatar
Just to clarify, I was responding to odiaz1831's request about an aluminum intake manifold replacement, not the input nut thread
Old 07-10-2018, 04:49 PM   #13
odiaz1831
2003 ION-3 Sedan
Anyone have pictures and dimensions of the nut? Currently emailing a machining company by my house.
Old 07-10-2018, 05:33 PM   #14
odiaz1831
2003 ION-3 Sedan
[QUOTE=toggenburg;2277262]That's a huge block of aluminum to CNC mill down to make just one,let alone cast one.
OR, repair it (watch)]
Haha yeah I know about thag fix, luckily mine is still in good condition. Was just wondering about a full metal intake seeing as there's a metal.replacement for the water spout.
Old 07-10-2018, 07:46 PM   #15
Waiex191
Waiex191's Avatar
yes, it is metric.
All aircraft hardware in the States is standard. For my airplane projects I've bought from Aircraft Spruce, Wicks, Genuine Aircraft Hardware, and eBay. The two airframers I've worked for, Sikorsky and Schweizer, used only standard aircraft hardware.
One of the problems with buying a foreign aircraft is they do use metric hardware. I used to own a Czechoslovakian glider. Very hard to source metric aircraft hardware.
Bryan Cotton
Old 07-10-2018, 09:53 PM   #16
There is a US company that probably has them. To find out I needed the thread diameter and pitch and it seems no one could be bothered so I dropped it. Saturn found them somewhere ... They are not cheap either.
Old 07-10-2018, 10:15 PM   #17
Saturn Night
It depends on the symptoms of the transmission, whether you should need to tighten the input shaft nut. And you can do MORE damage by messing with this and not using the proper tools for holding the clutch pack in place or by bending the two metal tubes on the side cover.
Reverse Slam/Delayed Reverse are symptoms of a worn boost pressure valve bore. Reverse requires the highest line pressure to engage the clutch. The internal leakage, from the bore being worn, causes the line pressure solenoid to try and correct it(hence the delay and slam, when the line pressure suddenly spikes).
A loose input shaft nut will cause slamming in ALL gears, as the line pressure solenoid is pretty much done by the time the nut starts getting knocked loose. It will cause a loss of reverse, until you rev to about 4k rpms, and a P0732 code for No Second Gear(Reverse is on the same clutch as 2nd Gear).
It is a TTY nut, or Torque-To-Yield, which is why you are not supposed to reuse them. The torqueing process causes the threads of the nut to "stretch", as a way to prevent them from loosening themselves by centrifugal forces of rotating within the transmission. It actually does cause damage, which is why they need thread locker when being reused.
Don't mess with it, if you don't have to. Start with the valve body.
Old 07-11-2018, 10:58 AM   #18
odiaz1831
2003 ION-3 Sedan
This is what I was attempting to get too, I think I'm just going to run to the salvage yard and remove one to get the dimensions. Don't wanna run my tranny
Old 07-11-2018, 11:00 AM   #19
odiaz1831
2003 ION-3 Sedan
Thanks man this is why I love this forum. All this information to absorb. This is exactly what I needed to hear, don't want to go around messing things up I don't have to. Besides bending the tubes when removing the clutch plate (I think that's the name) and the holding the clutch still, is there anything else major I need to be extra cautious about? Any bolts specifically that tend to get nice and rusted tight?
Old 07-11-2018, 01:16 PM   #20
The nut is not Torque-to-Yield it is a prevailing torque design nut.
input shaft shadowspiyre99 S-Series Tech 2 09-15-2010 03:44 PM
input shaft nut-shaft play chingondearmona S-Series Tech 9 06-30-2010 09:23 PM
how to jam input shaft for input shaft nut replacement. anisbet S-Series Tech 2 04-20-2009 12:54 PM
Input Shaft- What does it do? Scout238 S-Series Tech 8 11-14-2005 10:03 AM
A/T Input shaft nut Mr Bill S-Series Tech 1 03-17-2005 07:20 PM
