Old 06-25-2018, 12:06 PM   #1
slugbug
slugbug is on a distinguished road
1999 SC1
Default brake hose to brake line union?
Anyone have a link to the adapter which connects the front brake hose to the steel brake line? There appears to be an adapter which connect the two and join them to the L bracket. I'm trying to remove the two from the L bracket but they are so rusted I'll never get them off in one piece. I'll probably have to cut them off of the bracket.
Add to slugbug's Reputation
Rate the quality of this post and help slugbug reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
slugbug is offline   Reply With Quote
Old 06-25-2018, 02:30 PM   #2
slugbug
1999 SC1
Default Re: brake hose to brake line union?
Does the steel brake line screw directly into the rubber brake hose? On second look it appears this may be the case and the replacement NAPA hose having a little different look may have fooled me int thinking the original Saturn brake hose may have had an adapter to connect the two. Regardless I'll have to cut te old lines off the bracket to attach the new ones securely.
Old 06-25-2018, 03:09 PM   #3
Waiex191
Waiex191's Avatar
The solid brake line screws directly onto the metal end of the rubber hose. A clip holds the metal end of the hose to the L bracket.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 06-25-2018, 11:27 PM   #4
Waiex191
Waiex191's Avatar
A couple of pictures here:
http://www.saturnfans.com/forums/sho...&postcount=236
Bryan Cotton
I had to cut brake line at caliper hose... raymondjiii S-Series Tech 8 04-22-2018 09:43 AM
Does anyone know the name of the brake line/hose bracket? owbowagowy Vue General 5 10-09-2016 06:01 PM
Brake Line Fitting / Union Question myoldsaturn S-Series Tech 4 03-20-2016 06:33 PM
Steel Fuel Line?? Brake Hose?? cola S-Series Tech 6 11-16-2010 11:12 PM
Brake hose/line problem Diaconic S-Series Tech 2 07-17-2005 04:13 PM
