Old 06-24-2018, 11:06 PM   #1
CarSexer
CarSexer is on a distinguished road
Default 2002 SL2 pedal inquiry
Hi all,
Iíve had my Ď02 SL2 for over 13 years now and Iím damn proud to say I own it. I let my buddy, Patrick, take it for a spin recently. He mentioned that the pedal was acting like a sports pedal set up. The pedal is like on a hinge/joint, so you can apply pressure from whatever angle and it reacts.
This is the first Iíve heard of something like this. I never noticed this until my friend brought it to my attention. Now that Iím aware of this, I canít help but notice it every time I take the SL2 for a drive. I donít have an issue with it. But I want to make sure that itís a standard thing, and not a problem with my SL2 in particular.
Any help and/or advice would be great!
Best regards,
-Dave
-David
Proud owner of:
ďSashaĒ 2002 SL2... still runnin !
Add to CarSexer's Reputation
Rate the quality of this post and help CarSexer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
CarSexer is offline   Reply With Quote
Old 06-26-2018, 11:29 AM   #2
Default Re: 2002 SL2 pedal inquiry
Gas pedal? Clutch? Brake?
not familiar with "sports pedal" . . . I usually apply pressure to all three pedals from the front. Not sure I get what you are describing
Old 06-26-2018, 12:05 PM   #3
toggenburg
toggenburg's Avatar
Totally normal for a saturn s series.
Some cars are hinged at the floor level, ours aren't, but rather hinged partway up and not attached to the floor at all.
Old 06-26-2018, 12:31 PM   #4
Waiex191
Waiex191 has a spectacular aura aboutWaiex191 has a spectacular aura about
Waiex191's Avatar
The VW bug comes to mind. The original, not the sequel.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 06-26-2018, 12:34 PM   #5
I haven't seen a floor-hinged pedal in a while.
ditto with the floor-mounted high beam switch. Used to be a momentary switch mounted by the left foot, stepped on it to turn high beams on/off.
Lasted maybe a couple of years before getting badly rusted, location was not a good idea
Old 06-26-2018, 03:54 PM   #6
toggenburg
toggenburg's Avatar
^^ Agreed about the rusting issue.
However; it was a great source of fun for this dad when his sons were smallish.
I would have the headlights on low beam, tell my boys that in say, 5 seconds the high beams would be on for 5 seconds, then turn off again to low beams....
After the 2nd cycle through, they would have caught on, but ah it was a bit of fun for awhile. They still remember those good times.
Old 06-26-2018, 04:14 PM   #7
Waiex191
Waiex191's Avatar
I miss high/low beams on the floor. Never saw one rust out.
Helicopters have basically the same switch on the floor for transmit. It is a momentary switch though. It is set up for your right foot in American helicopters.
Bryan Cotton
2002 Saturn Vue Clutch Pedal Not Working. vuedriver Vue Tech 1 03-15-2015 07:48 AM
2002 sl clutch pedal? sl_don S-Series Tech 3 09-14-2014 02:15 PM
New 2002 Saturn L200 owner. Stereo and general inquiry. GoatAndMonkeys L-Series General 9 01-30-2014 11:01 AM
SL2 2002 Clutch Pedal Loose TXSaturn02 S-Series Tech 9 07-15-2009 10:54 AM
2002 S Series Brake Pedal Recall hugh S-Series General 1 04-26-2002 09:10 PM
