Old 06-24-2018, 07:00 PM   #1
92sl2
92sl2 is on a distinguished road
Default Fuel Line Repair
1997 SL2 120K-ish
Discovered that something seems to have chewed on the fuel line. Searching the forums turned up http://www.saturnfans.com/forums/sho...d.php?t=232637 in which sedativechunk talked about installing a fuel line union for a small damaged area of line. TheBuild had previously posted asking about such a part, and posted a link to one that is 8 mm.
The question is, is 8 mm the correct size? And if so is it possible to use that part for the damage seen in the attached picture? Or is there some other way to patch this piece of line? Visual inspection of the lines did not turn up any other damaged areas and fuel was only seen to be leaking from this one area.
Add to 92sl2's Reputation
Rate the quality of this post and help 92sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
92sl2 is offline   Reply With Quote
Old 06-25-2018, 01:07 PM   #2
92sl2
Default Re: Fuel Line Repair
Well I cut the damaged piece out - it's too long for a union. So I got a piece of fuel line and some barbed fittings. Now the question is - are the fittings supposed to go all the way in (ie, to the middle, where the stop is)?
Old 06-25-2018, 05:46 PM   #3
billr
billr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of light
Yes, push them on as far as they will go. Warm the lines up with a heat-gun or hair-drier or by dipping the ends in water that has recently been boiled.
Add to billr's Reputation
Old 06-25-2018, 10:08 PM   #4
92sl2
Perfect, thank you. Should the line be clamped at all, or will the fact that the line is semi-rigid be enough to hold it?
fuel line repair help needed.. 1993 S-Series Tech 7 05-14-2017 09:30 PM
Fuel line repair? pocomenomosso Vue General 16 01-30-2017 10:49 AM
Fuel Line Supplier?-pressurized line is leaking Reliabilityman S-Series Tech 1 05-06-2015 11:31 AM
Aeration line repair fetchitfido S-Series Tech 2 10-16-2013 08:17 PM
Brake line repair... Craig S-Series Tech 5 04-10-2005 05:36 AM
