Old 06-24-2018, 04:59 PM   #1
Hiram_32
Hiram_32 is a glorious beacon of lightHiram_32 is a glorious beacon of lightHiram_32 is a glorious beacon of lightHiram_32 is a glorious beacon of lightHiram_32 is a glorious beacon of light
Default 02 SL2 Trouble Codes P0708 (2 instances), P0037, plus VB issue/questions
Got the following trouble codes:
02 SL2 with 154k on engine
Second Owner
-P0708 Trans Range Sensor High Input (twice in a row)
-P0037 HO2S-12 (Bank 1 Sensor 2) Heater Circuit Low Input
The codes remained after having about 4-5 other codes (don't have info onhand--will post later), one of which indicated TCC Stuck On or Off. Proceeded to remove VB and test solenoids, only to find out that the multimeter I was using was faulty (set to correct 200ohm), and was giving high readings of solenoids (16.7 or so). Swapped out with new multimeter, and all solenoids tested around 5.9.
PROBLEM (self-created): When closing up VB after reattaching to trans, the last bolt wouldn't toque down flush with the VB as it was the incorrect length. Under duress (1am, had to work next morning), torqued bolt to spec, despite it not going down flush with VB casing, and closed up Trans Pan. Out of necessity (intense work sched, no backup car), been driving the car for 1 week, putting on at least 200 miles. It should be noted that over 2yrs ago, I successfully (and correctly) replaced a bad solenoid, which solved some reverse slamming I had been experiencing (caused by dodgy home mechanic-- left trans filter 3/4 on, leaked trans fluid without my knowing about it for over 1000miles).
SYMPTOMS:
-Hard reverse slamming (wasn’t as pronounced before removing VB and improperly sealing it)
-Slamming when shifting into drive (not nearly as intense as R)
-On 3 occasions, shifting into R has acted as if it were in D (remedied after shifting into N then back into R)
-Slamming into high gears when driving on highways (been like that since I got the vehicle)
QUESTIONS:
-Any suggestions/links/tutorials on how to remedy codes?
-Did I screw up the trans now? Or does it seem like it will be okay after correcting VB bolt positions?
-Can anyone please share or direct me to info/images for the correct VB bolt positions?
-Would it be advisable (or even make sense) to buy a new VB and swap it with old one?
-Someone suggested this could be a chain linkage issue—thoughts?
Any feedback, suggestions, solutions are greatly appreciated. Thank you!
Add to Hiram_32's Reputation
Rate the quality of this post and help Hiram_32 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Hiram_32 is offline   Reply With Quote
Old 06-25-2018, 09:56 AM   #2
Chazberry
Chazberry's Avatar
1995 SW2
Default Re: 02 SL2 Trouble Codes P0708 (2 instances), P0037, plus VB issue/questions
First check the ground wire on your Range Switch.
Here's the diagram that shows bolt lengths . . .
http://www.saturnfans.com/forums/att...6&d=1416505869
Add to Chazberry's Reputation
Old 06-26-2018, 07:50 AM   #3
Hiram_32
Where is the ground wire located for the Range Switch?
Thank you for the diagram!
Old 06-26-2018, 09:15 AM   #4
Chazberry
Chazberry's Avatar
1995 SW2
It goes from the Switch to the Chassis . . .
http://www.saturnfans.com/forums/sho...2&postcount=11
Old 06-26-2018, 10:40 PM   #5
Hiram_32
Thank you for this.
Old 07-12-2018, 10:09 AM   #6
Hiram_32
@Chazberry: Thank you for pointing out the Range Sensor grounding. Turns out the cord had gotten ripped out of it's clip as a result of pulling the wire harnesses away from the valve pan. Reconnected the wire, and it solved the shifting problem---for short time.
The reverse slam issue is still happening, though not as intensely. Still experiencing hard shifts into higher gears, and have noted the RPM is greatly disproportionate to the MpH (30MpH, 60RPM for instance). Also, the engine idles high, I think around 15 or so RPM from what I recall (will make note later).
NEW CODES POST-REPAIR (as appears on print-out):
P0037 HO2S-12 (Bank 1 Sensor 2) Circuit Low Input
P0410 Secondary Air System Performance
P0741 TCC Solenoid Circuit Performance or Stuck Off
Any insights as to what is causing these? The P0410 is brand new, and have never gotten that code before in the past. Also, what would cause the P0741 when I know the TCC solenoid to be good (5.9 Ohms)? Should I buy a rebuilt TAAT transmission off Ebay and swap it out with the old one? It should be noted that I did not reuse the old trans fluid, as the first time it was mistakenly opened by a foolish home mechanic, the fluid all got dumped. I note this, as a few folks I've spoke with said reusing old fluid can be helpful as the particulates help keep the internals shifting well after they have worn from years of use (156k on engine).
As always, insights, feedback, and remedies are greatly appreciated.
Old 07-12-2018, 12:27 PM   #7
Saturn Night
I would contact Special Forces and order a new Valve Body. Reverse Slam has always been present, which means the Valve Body is shot.
Slamming in forward gears is likely an issue with the pressure regulator valve bore and/or the line pressure solenoid.
Special Forces will send instructions on which bolts go where.
Fixing the engine codes will also help with shifting. If the engine misfires, runs too rich/lean, it will cause poor shifting.
Old 07-12-2018, 12:32 PM   #8
Saturn Night
And make sure to change the fluid. The Saturn TAAT is the one transmission, that changing worn fluid will not hurt it. My TAAT had 163k, reverse slam, a quirky downshifting issue when cold, and the TCC solenoid was sticking. The fluid had never been changed and it had a factory trans filter still on it.
Changed the fluid. Replaced the valve body. Currently at 197k. Just did my scheduled service at 193,999 miles, for the trans fluid, since I did the repair work.
Runs and shifts fine. Has even gone to the drag strip a few times and been beat on going down the track at WOT.
Old 07-12-2018, 03:00 PM   #9
J.W.
J.W. is a jewel in the roughJ.W. is a jewel in the roughJ.W. is a jewel in the rough
2001 SL2
[QUOTE=Hiram_32;2276200]Got the following trouble codes:
Second Owner
Somewhere in the archives is a lot of info about the electrical plug wires on top the automatic tranny. They tend to vibrate a bit and break inside the insulation. That broken wire(s) give you the indications you describe.
Check that out before you get into the tranny...it can be just a broken wire.
Maybe someone remembers that ?
JW
Add to J.W.'s Reputation
Rate the quality of this post and help J.W. reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
J.W. is offline   Reply With Quote
Old 07-16-2018, 04:36 PM   #10
Hiram_32
@Saturn Night
Thank you for the feedback! A compromised VB seems to make sense here, given all these issues popping up. I'll look into Special Forces VBs. Will also change the fluid, too.
Old 07-16-2018, 04:40 PM   #11
Hiram_32
[QUOTE=J.W.;2277413]
Second Owner
JW
@JW
Thank you for the info! I was wondering about electrical issues, and will investigate this further. Is there any way to assess broken wires when they are exposed from their color-coded cover? Would it be advisable to replace the wires to the VB/wiring harness and plug altogether? Clipping them back a few inches from wiring harness and replacing with a new one? If so, have you any suggested resources for getting a new set of wires/wiring harness? There's a U-Pull yard not too far from me I could call and ask about said part.
Old 07-18-2018, 02:31 PM   #12
J.W.
2001 SL2
[QUOTE=Hiram_32;2277779][QUOTE=J.W.;2277413]
@JW
Thank you for the info! I was wondering about electrical issues, and will investigate this further....
Sorry for this late reply.. From memory : The wires going from the flat plug on top the tranny can be examined by feel. remover the wrapping going back about 8 " or so to the main harness. If the wire is broken, it may show as a bump in the insulation, a thin spot in the insulation , or some other anomaly.
I'm currently doing similar trouble shooting. I have found no suspect wires. I do have a test probe with a needle point with which you can carefully puncture the insulation (hoping to hit the conductor) and the other meter probe to the contact on the plug ( plug removed from socket ). then with your 3rd or 4th hand try to gently wriggle the wire. It's not the best way , unfortunately it's about the only one. Ideas welcome ! !
A new plug can be ordered, with pigtails for about $ 70. 00 . Try doing a search on this site for more info, including plug part numbers etc.
If you find the cause... spread it around !
Jack
Old 07-18-2018, 02:45 PM   #13
J.W.
2001 SL2
@Saturn Night
More info, Hiram..
Hiram -
This is the only reply method that works ..for me anyway ..
If you search for "transaxle connector (P/N 21024415)", that will bring up much info. Ol Nuke has the plug pin out on his site...you can print it out.
...JW
Old 07-18-2018, 09:04 PM   #14
Hiram_32
[QUOTE=J.W.;2277910][QUOTE=Hiram_32;2277779]
Originally Posted by J.W. View Post
@JW
Jack
Thank you for all the info, JW! LOL at 3rd & 4th hands. I think those are available on amazon. =P So basically, the wire diagnostic procedure is rather involved, but sounds like the only way to go about doing it given the available info. Considering the price of the plug with pigtails, and my currently tight time budget, it's almost wort ordering that and swapping it out, IMO. Indeed, will share the details when a cure is found.
Old 07-20-2018, 07:42 AM   #15
Hiram_32
To rule out other potential factors causing these issues, could something such as the alternator be causing problems? Or bad fuses or relays? Also, it should be noted that the 02 SL2 has been experiencing occasional trouble starting up, where I hold the ignition, and it takes a few seconds to start, and yesterday, where it didn't start after a few seconds, and when I tried again, it started no problem (engine still warm at that point).
Old 07-21-2018, 07:57 AM   #16
Hiram_32
Furthermore, it should noted that I have new shift solenoid purchased off ebay sitting around. I've read on a couple of posts on here that a solenoid can be bad but still read the correct Ohms--is this true? If so, would it be advisable to swap of the TCC solenoid with the new one, seeing as it is only one that comes up as a trouble code?
Old 08-27-2018, 10:45 AM   #17
Hiram_32
Happy Re: 02 SL2 Trouble Codes P0708 (2 instances), P0037, plus VB issue/questions
UPDATE: Bought a rebuilt VB from Ken Partin (a very friendly, funny, helpful fellow), and swapped it out with the old one about a month or so ago. Wasn't clear on how to perform the learn-in procedure, so I drove the car locally for the first day, then drove it to work and back for the next 3-4 days. I am pleased say that the hard-shifting issues (reverse and forward gears) are gone, and the car is shifting very smoothly now.
That said, I do have the same old issue the car's always had, where it goes into very high RPMs when going full throttle on freeways to pass other drivers ( snapped a photo of the RPMs when it happened and will upload it when time permits). Overall, it appears that the shifting issues are resolved, so if other folks are getting the reverse slam and hard-shifting in forward gears, and replacing solenoids doesn't solve the problem, it may be worthwhile to buy a rebuilt VB and see if it helps. Ken Partin offers a full-refund policy after install if it fails to solve the problem, so all the more reason to give it a shot if signs point to the VB.
Thank you all for the helpful feedback and suggestions!
2004 Ion with P0031 and P0037 codes memorizeme Ion Tech 1 08-10-2015 07:11 PM
trouble codes wadenie S-Series Tech 3 12-22-2011 08:18 PM
Trouble Codes m2k_us Ion Tech 0 11-07-2009 08:06 PM
Trouble with Transmission Trouble Codes Toaster_Man S-Series Tech 0 05-22-2008 07:32 PM
'92 SL2 trouble codes Alex's Dad S-Series Tech 7 03-30-2002 09:24 PM
