Old 06-21-2018, 01:26 PM   #1
maitai_1
maitai_1 is on a distinguished road
Default Used engine swap
Ok so I'm about to swap in a used motor I to my 1996 sw2 is there any thing I should replace befor the new 7sed motor goes in. It's a 1998 1.9 with 153k miles and was running befor pulled. Just asking if.
Add to maitai_1's Reputation
Rate the quality of this post and help maitai_1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
maitai_1 is offline   Reply With Quote
Old 06-21-2018, 03:29 PM   #2
Default Re: Used engine swap
Originally Posted by maitai_1 View Post
Ok so I'm about to swap in a used motor I to my 1996 sw2 is there any thing I should replace befor the new 7sed motor.
Took me a second to realize 7sed = used
I'm pretty sure you have to bring your fuel injectors and fuel rail from the 1996 motor to the 1998 motor.
There's a few sensors on the back of the engine that are easier to replace while the engine is out of the car. If cost is a concern, this is optional - no need to fix if it ain't broke.
Also optional, some folks like to clean the intake as it gets some thick, oily gunk. For that matter, with those miles, the EGR passageway may not be a bad idea - pull the exhaust and go in from that way.
One of Low Saturn's tips, replace the top starter bolt with a stud - the exhaust ones will fit. makes replacing the starter easier.
Oh, since the motor is out, gently backflush the heater core
There's been several threads, maybe a search will pick up something else.
Old 06-21-2018, 04:05 PM   #3
onlinebiker
onlinebiker is a jewel in the roughonlinebiker is a jewel in the roughonlinebiker is a jewel in the rough
Pretty sure the alternator is different as well.
92 SC2
93 SC2
93 SW2
97 SL2
97 SC2
99 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
3 96 SC2
Old 06-21-2018, 04:14 PM   #4
Use the accessories from the 96 if the 98 does not have a compatible part. Replace the waterpump and use the 96 fuel system. You can use the entire 96 intake manifold assembly and make life easier, likewise the 96 exhaust manifold. Do not start swapping sensors with no reason/justification, the exception would be the ECTS --buy a new one. A new Denso or NGK front O2 sensor could save you a world of grief.
Old 06-21-2018, 07:25 PM   #5
maitai_1
5hanks for the help but I found a 1996 dohc motor straight swap np problem.
Old 06-25-2018, 04:26 PM   #6
maitai_1
Ok another swap question what about 1996 dohc into a 1994 sw2. Every thing looks the same on the motors except the valve cover the 1996 is black and the 1994 is silver.
Old 06-25-2018, 06:26 PM   #7
maitai_1
Sorry for the confusion the car is a 1995 dohc and I'm swapping in a 1996 motor. What harness do I use and is there any thing else that need to swap over.
Old 06-25-2018, 06:42 PM   #8
When swapping engines you use the existing wiring anf electronics. In the case of the 95/96 you will have to drill and tap a hole in the head for the gauge single wire sensor. Easy spot is the top of the head water outlet. Between the head and teh hose seat bump, ther is just enough room.
Old 06-25-2018, 08:24 PM   #9
maitai_1
Thanks for the info. Also looks like I need to swap injectors/fuel rail from the old eng.
Old 06-25-2018, 09:39 PM   #10
Saturn Night
If you are placing the 1996 engine into the 1995 model, you will need to swap the injectors and use the 1995 harness because it is OBD-I. OBD-I uses 12.5ohm injectors. The 1996 engine uses 2.5ohm injectors, and will blow the fuses sky high.
As Nuc has stated, you will need to drill the cylinder head casting for the temperature sending unit(most machine shops will NOT do this), or you will not have a working temperature gauge.
Swap the 1995 O2 sensor from the manifold. Should be a single wire. From my understanding, the 1996 O2 sensor will not cause a SES light, I am not sure about the plug matching the 1995 harness or not.
Swap the valve cover, as well, since the 1996-1998 covers are junk and warp which causes oil leaks.
Old 06-25-2018, 11:10 PM   #11
DO NOT SWAP ANY WIRING HARNESS! All you have to do is swap the injectors into the 96 rail, they are a direct fit and the PCM, NOT THE HARNESS, is what determines the injector impedance requirements.
All of the 18mm O2 sensors will swap with no issues IF they have the correct connector, you can tell by looking.
Old 06-26-2018, 03:36 AM   #12
maitai_1
@oldnuc yup I got that part thanks. I did notice thoe that it seams like the knock sensor uses a different plug not for sure yet. But yah I'm reusing the original cars harness on the new motor.
Old 06-26-2018, 07:31 AM   #13
onlinebiker
Yup. Use knock sensor off original engine.
I did the same swap the other direction....
95 engine into 96 body.
It worked our well except for I missed the injectors and kept blowing a fuse everytime it hit 4000 rpm.
The good gentlemen here pointed out the error of my ways, I swapped injectors - and it' s run like a Rolex since...
92 SC2
93 SC2
93 SW2
97 SL2
97 SC2
99 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
3 96 SC2
Old 06-26-2018, 08:27 AM   #14
Knock sensor does not use a different connector. Any connector issue will become obvious and you will have the proper part in hand anyway. It is best to use the 95 TB on the new intake. Easy way to deal with the fuel-intake issue is to just swap the entire 95 intake onto the 96 engine. You also must use the 95 exhaust manifold and while all of this is apart VERIFY by Presure Test that the exhaust has NO leaks.
Exhaust leak check.
--Locate a low pressure high volume air source, reversible vacuum cleaner, large fan, leaf blower or what ever you can find.
--Loosely couple to cold exhaust at the tail pipe, or direct fan at tail pipe.
--Spray every inch of the exhaust between the head and CAT outlet flange with a mixture of 2 or 3 drops of dish soap and water in a spray bottle.
--Pay close attention to the lower flange, lower support clamp, and flex connector.
--The flex connector is under the protective braid so it requires quite a bit of solution to show any leaks.
Old 06-26-2018, 02:48 PM   #15
onlinebiker
Exhaust leak check.
Slick!
Never seen that on exhaust. Do it all the time hooking up propane equipment.
I' ll have to remember that one. It WILL get used. No more sending the old lady up for a fun ride up on the lift.. "Start it!!".
92 SC2
93 SC2
93 SW2
97 SL2
97 SC2
99 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
3 96 SC2
Old 06-26-2018, 03:37 PM   #16
maitai_1
I want to replace timing chain and water pump on new motor any recommendations on were to order timing chain set. Are the Ebay ones safe my local auto store wants $175 for timing chain set.
Old 06-26-2018, 03:45 PM   #17
Some people have had issues with the eBay chains (I think one guy had an extra link or something weird)
That said, I put an eBay timing set on my '98 SL2, and it's still in there running strong after 100k miles and 8 years, and many others had no problems, either
Old 06-26-2018, 05:54 PM   #18
maitai_1
New problem didn't even think about till now if old motor is locked up how do I remove fly wheel to TQ converter bolts.
Old 06-26-2018, 10:20 PM   #19
maitai_1
Was able to get the motor to turn and got out the flywheel bolts. I'm thinking there's a bad bearing in there motor turned but bearly had to use 1/2in brake and cheater pipe.
Old 06-27-2018, 09:23 AM   #20
Put a tablespoon of oil in each cylinder and turn engine over 2 complete turns. It has been setting dry for no one knows how long, everything is dry.
Easier to Swap engine, or swap tranny? Saturn #4 S-Series General 6 03-21-2016 09:44 AM
Engine cradle swap; tranny swap MikeNW S-Series General 6 03-11-2015 01:04 AM
Engine swap help. Can you swap without taking off the transmission? 99 sl2 5-speed msmay0 S-Series Tech 5 06-10-2012 05:01 PM
engine swap ? 99 sl2 swap in 98sl2 jiffypop S-Series Tech 1 12-11-2010 11:14 AM
Engine Swap or trannie swap SL-2er Miscellaneous Tech 1 04-28-2003 05:00 PM
