Old 06-21-2018, 10:26 AM   #1
stefanP
stefanP is on a distinguished road
Default In chassis engine overhaul??
Has anyone done a in chassis overhaul?Thinking about it .Also looking to buy a remanufactured cylinder head.Recommendations??
Add to stefanP's Reputation
Rate the quality of this post and help stefanP reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
stefanP is offline   Reply With Quote
Old 06-25-2018, 02:17 PM   #2
Cavell
2004 VUE 3.5L
Default Re: In chassis engine overhaul??
what year/motor? i went thru the heads on my 3.0. you probably will be able to pull pistons/rods on any motor in car. cant do the rear main seal and its hard to reach front seal/cover due to frame rail. so saying overhaul is somewhat sketchy.
Add to Cavell's Reputation
Old 06-25-2018, 02:45 PM   #3
RGRG68
RGRG68 has a spectacular aura aboutRGRG68 has a spectacular aura aboutRGRG68 has a spectacular aura about
2004 VUE 2.2L
At least on the 2.2 you kinda can.. You can do rings, wrist pins and rod bearings....and of course the entire head.. but.. like the other poster..no rear main.. in 2.2 the front main is accessible if memory serves. This would leave out replacing the crank and honing the cylinders.. (would be very tricky).. and crankshaft bearings /thrust bearings. I did the rear main when I did the clutch...
Add to RGRG68's Reputation
Rate the quality of this post and help RGRG68 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RGRG68 is offline   Reply With Quote
Old 07-17-2018, 07:56 PM   #4
stefanP
Default engine removel??
I assume through the bottom /,Not the top?
time for an engine overhaul Dark_Lotus30 S-Series Tech 1 12-25-2012 01:34 PM
1995 SC1 Engine overhaul Panzer23 S-Series Mods 1 12-14-2010 05:13 PM
Engine Overhaul? justinflo200 S-Series Tech 1 06-16-2007 04:48 PM
Engine Overhaul RyanEricW S-Series Tech 11 04-23-2007 02:10 PM
Overhaul or New Engine? Whadda ya think? Shinner S-Series Tech 28 07-20-2006 10:58 PM
