Old 06-20-2018, 09:06 PM   #1
TimT
TimT is on a distinguished road
Default Water leak
1996 SW2 . I am replacing the carpet in my wagon and when I pulled it up I found water on the passenger side floor board under the carpet. It looks like it is coming from behind the sound deadening pad o the firewall. Anyone have any ideas on where this is coming from?
Tim
Add to TimT's Reputation
Rate the quality of this post and help TimT reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TimT is offline   Reply With Quote
Old 06-20-2018, 11:44 PM   #2
Chub
Chub will become famous soon enough
Chub's Avatar
Default Re: Water leak
Two most likely culprits:
1) the smile joint between the firewall and the spaceframe
2) your A/C drain is clogged and the condensation is draining into the car
To fix option 1, it is a pain in the neck but you will have to reseal the firewall seal that has now rotted. For option 2, stick a pencil or other object into the A/C drain and check that it doesn't have crud in there clogging it up. Try option 2 first and check for a proper drain / puddle under car. If you think it is option 1, I tacked this repair and I can give you some tips but it is anything but fun or easy.
1995 SC2: Back on the road again after my second engine rebuild in two years.
Add to Chub's Reputation
Rate the quality of this post and help Chub reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Chub is offline   Reply With Quote
Old 06-21-2018, 09:40 AM   #3
ErikTande
ErikTande will become famous soon enough
ErikTande's Avatar
Does it smell like coolant by chance? If so it might be a leaky heater core.
http://www.youtube.com/velocitylabs
Add to ErikTande's Reputation
Rate the quality of this post and help ErikTande reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ErikTande is offline   Reply With Quote
Old 06-21-2018, 10:10 AM   #4
Cheyne
2000 SL2
Check the oval-shaped foam gasket/screen on the fresh air intake located on the cowl on the passenger's side under the hood.
Add to Cheyne's Reputation
Old 06-21-2018, 10:40 AM   #5
TimT
Where is the AC drain? Will check the gasket. And look at the fire wall.
Does not smell or look like coolant it is definitely water.
Thanks again
Tim
Old 06-21-2018, 12:26 PM   #6
Tim, meet our good friend, richpin
https://www.youtube.com/watch?v=W0VdFRDdgvA
He has a metric tonne of Saturn-specific videos.
Old 06-24-2018, 12:34 PM   #7
TimT
Update on the water leak. Checked the AC drain and it's clear. Ran a brush and a long zip tie up it. Thanks for the richpin link. The firewall seal looks good. The fresh air seal was dry rotted and there is a hole next to it that at one time was sealed with silicon. The hole was not sealed and the plug fell out. So I made a new seal out of rubber insulation I got at Home Depot and used the old screen. I then got a rubber plug from Pep Boys and put that in the hole with some silicon . Time will tell if I got it worked out.
Old 06-24-2018, 05:23 PM   #8
Cheyne
2000 SL2
The gasket at the fresh air intake was most likely the cause. Your repair will work if you didn't use the really thin material where the water could overrun it. I keep a roll of EPDM in the shop as it has many uses.
Old 06-26-2018, 04:26 PM   #9
hholbein
1997 SW2
+1 on that. The foam screen sandwich that vents the cowl area is a pretty flimsy design and a frequent source of passenger-side floor leaks. The peel&stick adhesive goes first, and then the foam starts to disintegrate. I think I ended up refabricating it and gluing it in place with silicone. Must be 8+ years on the repair, and no problems since.
Another weird sort of leaks can be the rubber drains in the firewall for the cowl. Over the years tree droppings and dirt can plug them up, especially the ones under the wiper motor/transmission assembly. The buildup over decades can be significant, so removing/cleaning/replacing these is another quick fix.
Add to hholbein's Reputation
Water Leak ED1 Vue Tech 4 01-22-2015 01:45 PM
Water leak 04RDLN Vue Tech 3 06-18-2013 02:39 PM
Water Leak Mike94SL2 S-Series Tech 0 05-01-2006 07:45 PM
water leak sinisa S-Series General 7 11-18-2005 03:42 PM
A/C water leak? FL_SL2 S-Series General 6 03-02-2005 12:08 AM
