Old 06-20-2018, 05:05 PM   #1
originalhandy
originalhandy is on a distinguished road
Default Removing rear passenger door panel (2007)
I pulled off the wood trim and removed the two screws underneath the handle.
Is there something else I need to pull off before I can get it off? I see the plastics around the door opener but I can't get that off at all, does it need to? What's the trick ?
Add to originalhandy's Reputation
Rate the quality of this post and help originalhandy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
originalhandy is offline   Reply With Quote
Old 06-20-2018, 10:19 PM   #2
originalhandy
Default Re: Removing rear passenger door panel (2007)
I saw the bolt behind the pull handle to open the door and got that off . Does that unit with the switch pull out or should the door lift off as is?
Any tricks on pulling the panel off ? I looked around and saw no screws anywhere underneath or anything
Removing rear door panel gweimer1 Vue General 3 05-03-2012 08:36 AM
Help in removing L rear outer door panel Warren Webb L-Series Tech 3 08-28-2010 10:42 PM
Removing front passenger quarter panel HELP? Tanro S-Series Mods 11 07-22-2007 10:16 PM
Trouble removing outer rear door panel on 1997 SL2 kmcgillivray S-Series Tech 2 09-07-2004 07:27 AM
Trouble removing outer rear door panel on 1997 SL2 kmcgillivray S-Series General 2 09-06-2004 07:02 PM
