Old 06-19-2018, 08:28 PM   #1
spenser4
spenser4 is on a distinguished road
Default Fuel injector harness
I have a 2003 Vue 3.0 engine. I have a P0301 code. The Service manual want me to do a coil value test and a pulse test. Can't get to the injectors the way they connect under the intake. I know from experience when you completely remove the intake. Under the 2 intake runner controllers there are 2 electrical connectors you unplug. Can somebody tell me if one or both of them are for the injectors. I can go to u pull it bone yard and cut the main cable side connector. I have the wiring for the injectors code. I can cut enough wire back and connect them to the intake side. Then I can easily measure the injector values. I can also connect my injector pulse tool so I can pulse and measure the fuel drop if need. Thanks!
Add to spenser4's Reputation
Rate the quality of this post and help spenser4 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spenser4 is offline   Reply With Quote
Old 06-19-2018, 10:25 PM   #2
Default Re: Fuel injector harness
Each coil pack consists of three ignition coils, fired by the ecm. Each coil pack has it's own connector to the main wiring harness going to the ecm. If you can, disconnecting the coil pack for cylinders 135 and connecting a spare coil pack will allow you to test the spare but you'll have to either run some wires from each output to near ground for a spark test or connect three spark plugs to the spare coil pack and ground all three plug bases. Someone turns the ignition switch to START while you observe for spark on all three plugs. If spark plugs haven't been replaced every 100k miles, they may be worn. If this engine is well over 150k miles, other issues may have occurred - valve wear, piston ring wear, blown head gasket, burned exhaust valve.......
Injectors have their own connectors, six connectors for six injectors.
injector harness extended, now no workie? DJTricky Vue Tech 8 06-19-2012 10:59 PM
cannot plug 00 injector into 02 harness audettetractor S-Series Tech 6 02-24-2012 03:14 PM
Injector Harness Connectors Sevillian273 S-Series Tech 2 05-22-2010 07:36 AM
Fuel Injector Location? Engine Code says clogged injector. tAURAnce_guy Aura General 4 05-19-2010 06:17 PM
Fuel Injector / Fuel System cleaners AJT_Leo S-Series Tech 2 07-09-2007 04:30 PM
