Old 06-19-2018, 04:38 PM   #1
TimT
TimT is on a distinguished road
Default Throttle body swap
I'd like to do a throttle body swap. I know about the Geo/Isuzu TB but can't find one. Unless there is some one out there willing to sell me one. Anyhow what other TB work with our sensors. I don't mind a bit of machine work or electrical to make this happen.
Tim
Add to TimT's Reputation
Rate the quality of this post and help TimT reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TimT is offline   Reply With Quote
Old 06-19-2018, 11:09 PM   #2
Default Re: Throttle body swap
Pretty sure this is the small one, should be a nearly direct fit with minimal modification required: https://www.ebay.com/itm/52mm-SOHC-G...4AAOSwIM9bJIMK
The DOHC TB is the larger one, requires modifying our intake manifold hole as the stock S-Series TB fits inside the Storm DOHC TB.
One or the other or both also require relocation the throttle cable about 2" higher than the stock location.
Old 06-20-2018, 04:35 AM   #3
Saturn Night
The Geo Storm TBs will work, however, will only produce 80% throttle through the TPS and require fabrication of a throttle cable bracket.
www.car-part.com
As Fetch stated, the SOHC(52mm) TB is the easier choice because you don't have to port the intake manifold.
Old 07-08-2018, 10:56 AM   #4
Dunkinboom
Dunkinboom is on a distinguished road
Is there any way to get the to 100%?
It's not like it needs more gas pedal travel, cause with cable off, wot only goes to 80%
Add to Dunkinboom's Reputation
Rate the quality of this post and help Dunkinboom reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dunkinboom is offline   Reply With Quote
LSJ Throttle Body Swap w LE5 Throttlebody Adapter Plate Samtherecordman Ion Mods 18 07-20-2015 01:36 PM
03 L300 no start unless the throttle motor/ throttle body unpluged Woody117 L-Series Tech 2 12-25-2012 06:33 PM
Throttle Body 97saturnsl1 S-Series General 3 01-13-2007 03:50 AM
Throttle sticks - not throttle body - help! dannysm213 S-Series Tech 2 12-10-2006 04:20 PM
got a new throttle body rascon11 Ion General 4 06-12-2004 03:24 PM
