Old 06-17-2018, 11:46 PM   #1
cuetip
cuetip is just really nicecuetip is just really nicecuetip is just really nicecuetip is just really nicecuetip is just really nice
1997 SW1
Default AC Evap Core Flush Question
I need to flush the evap core in my '97 SW1 and was wondering what the inner and outer diameter of the inlet and outlet holes are at the firewall so I can fit some sort of tubing on or in them so I can direct the flush into a bucket
Add to cuetip's Reputation
Rate the quality of this post and help cuetip reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cuetip is offline   Reply With Quote
Old 06-18-2018, 12:44 AM   #2
Default Re: AC Evap Core Flush Question
I have no idea of inside diameters. However, If you are going to flush the evaporator core, you'll have to remove the thermal expansion valve that's sitting on the firewall connecting the ac hoses to it and the evap core. Leaving the txv in place may or may not allow solvent in or out since one side of this valve uses a needle to meter liquid refrigerant into the evap coils. If you're familiar with metering valves, google for how txv operates (block type). Once you get involved with txv removal, you open yourself up to another leak source as O-rings are used for the txv to evap fittings and another pair between ac hoses and txv. Once the txv is removed for full access to both evap tubes, any rubber cone sold with ac flushing solvent is used to force feed solvent under can pressure into the evap coils. Solvent, dirt and oil should blow out the other end. A tube to stick into the output tube can be used or just left as is and let solvent blow out and drain onto the ground or something to capture it.
Old 06-18-2018, 01:08 AM   #3
cuetip
1997 SW1
I had planned to remove the TXV. Was just wondering if anyone could tell me what size tube or hose works well so I don't have to guess
Old 06-18-2018, 08:31 AM   #4
SRGW
SRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of light
1997 SL1
Post Re: AC Evap Core Flush Question
https://www.carid.com/universal-air-conditioner/evaporator-plate-fin-mpn-ev2970pfxc.html?singleid=181445477&url=10413186#sp ecifications
1995 SL1 235,000 Well Oiled!!
1997 SL1 64,900 Just A Teenager!!
CHECK YOUR OIL!!
Add to SRGW's Reputation
Rate the quality of this post and help SRGW reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
A/C Evap Core Cleaning Question cuetip S-Series Tech 3 08-01-2016 09:06 AM
'97 SC2 heater hose removal for heater core flush SC2by2 S-Series General 3 10-24-2015 06:03 PM
heater core flush tyler1987 S-Series Tech 3 10-01-2010 02:52 PM
2005 Vue EVAP Question cpeterson7 Vue General 6 02-02-2010 08:08 PM
evap question night ryder S-Series Tech 2 05-22-2008 04:31 AM
