Old 06-17-2018, 06:22 PM   #1
buffumjr
buffumjr has a spectacular aura aboutbuffumjr has a spectacular aura aboutbuffumjr has a spectacular aura about
Default Power Requirement for SL radio
I have a radio my daughter took out of my 1995 Saturn SL when I gave it to her. I want to mount it in an enclosure and have music in my shop. I need to know what the required amps are. A have a 1 amp 12V power brick from my power brick box.
Any help appreciated.
Add to buffumjr's Reputation
Rate the quality of this post and help buffumjr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
buffumjr is offline   Reply With Quote
Old 06-17-2018, 07:52 PM   #2
Default Re: Power Requirement for SL radio
1amp should turn it on and work fine on "very low" volume, but for reasonable listening you should get a 5-8 amp power supply. Feel the brick after a minute or two, if it's warm or worse-HOT, it's not able to safely provide enough power to the radio.
On my unit that isn't powered from a PC power supply I use this: https://www.amazon.com/eTopxizu-Univ.../dp/B00D7CWSCG
Even has more ports so I can run a 12cm fan to keep things cool inside the box.
Old 06-17-2018, 08:45 PM   #3
buffumjr
Thanx. I'm going to SkyCraft tomorrow. I'll look for a 10A supply. SkyCraft is mind boggling in the electronics stuff & junk they have. Worse comes to worse, I'm sure there's a 10A brick out there.
What wattage speakers would you recommend?
BTW, the Saturn SL died an honorable death. On I-95, in the Ft. Lauderdale area, my daughter was stuck in traffic. A tractor-trailer rear ended the pickup behind her, and it hit her. Both the pickup and the Saturn were accordioned. My daughter, though hurt, was eventually OK. The Saturn had 250,000 miles on it.
Old 06-17-2018, 10:15 PM   #4
It only has about 10w max output so...any speaker above glorified headphones would work fine. Pretty much anything you can find either in the free pile or the under $5 bin (assuming used items). I think stock speakers are 8ohm so if you find the far more common 4ohm speakers it becomes more critical to get some active cooling going on (fan) though they'd go slightly louder (less ohms means louder for the same power, but also far far more heat in the amp) than with stock speakers.
Old 06-18-2018, 07:24 AM   #5
buffumjr
OOOH! I have some computer speakers with sub woofer lying around, gathering dust. They would be perfect, if that's all the unit puts out. All I have to do is find the right size jack.
'98 sl2 radio gets no power weezerfan4427 S-Series General 2 07-16-2015 08:37 PM
03 Ion no power to radio rickhouser Ion Tech 2 10-01-2012 05:19 PM
Radio power love2ridend S-Series Tech 2 11-06-2010 12:20 PM
Saturn Deal Didn't Meet Renault's Return Requirement Charlie General Saturn Discussion 3 11-11-2009 04:29 PM
