Old 06-17-2018, 05:15 PM   #1
flyhop
flyhop is on a distinguished road
2000 SL2
Default Oil change - Added too much...drain some?
Regular oil change. Including oil filter change, should have added 4 qts. Instead, I put in 4 3/4 quarts by mistake. Can I leave it in there? Or should I drain a little off?
1997 SL2, 5 speed, 270,000 miles.
TIA, Trey
Add to flyhop's Reputation
Rate the quality of this post and help flyhop reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
flyhop is offline   Reply With Quote
Old 06-17-2018, 05:29 PM   #2
toggenburg
toggenburg's Avatar
Default Re: Oil change - Added too much...drain some?
Mistakes can happen, but my DOHC usually used 4.5 quarts, and since it would lose oil on a regular basis, I just would ignore it and just beware next time to put in a little less.
But, most times I used the Purolator L20195 filter which is a bit longer than most filters.
Old 06-17-2018, 07:42 PM   #3
Signmaster
I'd just drain a little off.
Some of the owners manuals say you can be above the F mark by IIRC an 1/8 in or so on the dipstick, but maybe someone else can confirm that. But if you get overfull to the point that the crank is whipping into extra oil it's really not a good thing.
Old 06-17-2018, 08:03 PM   #4
Saturn Night
If you have an excessively high oil consumption rate(such as a qt/100-200mi), then no it won't hurt an already destroyed engine. It will be burning off so quickly, that it won't stay that full for a long enough time to damage anything.
If you are overfilled to the point that it is above the "U", in "FULL", and you are NOT excessively burning oil, then you will want to drain a little bit of it off or switch the to Purolator 20195/WIX 51516XL filter.
Old 06-17-2018, 08:22 PM   #5
Waiex191
Waiex191's Avatar
Before my Saturn was an oil burner, I'd be paranoid about overfilling it. After, it was self-correcting.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 06-17-2018, 08:31 PM   #6
Drained 2qts out of one once to get it down to the full mark. Smoked like a diesel at city speeds, didn't notice it at highway. Bought the car cheap & at night, didn't check the dipstick until I got home...what a surprise to see it over the 2nd "L" in full.
It still smoked at bit with the proper level of new oil but not nearly as bad as when I bought it. Burned quite a bit too but I've had worse.
Old 06-18-2018, 01:08 PM   #7
Saturn Night
Happy Re: Oil change - Added too much...drain some?
Saturn owners be like: "I live my life, one quart of oil at a time."
Old 06-18-2018, 01:26 PM   #8
RobertGary1
hahaha. No worries. It won't cause any issues. I accidently put almost 1/2 quart over the other day. I'm above the L in "full". No issues.
-robert
#7 added marko16 S-Series General 4 12-23-2015 02:13 PM
Trying to drain my radiator. NOTHING comes out of the drain. Help? DawnR S-Series Tech 39 07-23-2014 11:54 AM
Drain Oil before CKP change? AndreasChen S-Series Tech 5 02-03-2010 02:49 PM
XR Transmission Fluid Change-Drain Plug Location CT Aura XR Aura General 5 07-12-2009 08:04 AM
Added Hp mjdub S-Series Mods 6 06-27-2007 12:00 AM
