Old 06-17-2018, 09:53 AM   #1
LaboysToy
LaboysToy is just really niceLaboysToy is just really niceLaboysToy is just really niceLaboysToy is just really nice
LaboysToy's Avatar
2008 VUE 2.4L
Default U0121
Hi Everyone,
So I am driving home from work this morning on the highway in my 08 Vue XE I4 FWD doing about 60, and all of the sudden my Traction,Stability, BRAKE and ABS lights all come on at the same time (Never had seen this before while car is running), I get an on demand diagnostic from OnStar and they say it is due to error code U0121, Lost Communication With Anti-Lock Brake System (ABS) Control Module. Is this easy to fix?:
Add to LaboysToy's Reputation
Rate the quality of this post and help LaboysToy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LaboysToy is offline   Reply With Quote
Old 06-17-2018, 11:41 AM   #2
Default Re: U0121
Yes and no. It can be as easy as a worm out battery or as difficult as the abs system wiring or electronics fault. Two ways to look at this problem;
A power check of battery, battery cables, their connections, drive belt, belt tensioner and alternator output; https://repairpal.com/OBD-II-Code-U0...em-abs-control.
Jumping into abs troubleshooting; https://www.obd-codes.com/u0121
Old 06-19-2018, 06:20 PM   #3
LaboysToy
LaboysToy's Avatar
2008 VUE 2.4L
Default Re: U0121
Since I have no scan tool, took to the dealer and discovered its the EBCM.
Old 06-19-2018, 10:14 PM   #4
Default Re: U0121
The EBCM, electronic brake control module is GMs abs system.......
Old 06-20-2018, 12:31 AM   #5
LaboysToy
LaboysToy's Avatar
2008 VUE 2.4L
Default Re: U0121
Yes, I now know this and its pricey, I brought the part and will have them install. (Sigh) Im not sure why on the 2.4L they have that big black plastic airbox attachment to the engine blocking the engine cover, Its a pain to remove and makes most repairs annoying.
Old 09-08-2018, 08:22 PM   #6
LaboysToy
LaboysToy's Avatar
2008 VUE 2.4L
Default Re: U0121
I have not had a chance to have the part installed and now I have a code of C0550.
Old 09-10-2018, 11:01 PM   #7
dmayorgap
dmayorgap has a spectacular aura aboutdmayorgap has a spectacular aura aboutdmayorgap has a spectacular aura about
dmayorgap's Avatar
2008 VUE 3.6L
Default Re: U0121
Hi, same thing happened to my vue xr, i tested every wire and ground point that came out from the ebcm and everything was fine, i replaced the ebcm and solved everything.
Regards
David M.
Chevrolet Captiva Sport AWD V6 3.6
Add to dmayorgap's Reputation
Rate the quality of this post and help dmayorgap reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dmayorgap is offline   Reply With Quote
Old 09-12-2018, 08:21 PM   #8
LaboysToy
LaboysToy's Avatar
2008 VUE 2.4L
Default Re: U0121
I just brought the part, now have to get it installed, Is this a common issue?
Regards
Old 10-13-2018, 11:20 PM   #9
LaboysToy
LaboysToy's Avatar
2008 VUE 2.4L
Default Re: U0121
Update: I've decided to trade the VUE in for a 15 Terrain SLE2 that I got for a good deal with very low millage (19K).
