Old 06-12-2018, 09:43 PM   #1
vikasevan
vikasevan has a spectacular aura aboutvikasevan has a spectacular aura about
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Roll Eyes 2005 Saturn ION misfire and it sputters
2005 Saturn ION manual 197k miles
It starts and runs in idle ..does not overheat
I can drive it in neighborhood but I can not go on road ..
i.e. can not go pass 35 mph..
I believe after 20 mph it sputters when accelerator is pressed
recently changed spark plugs and coil pack but no change
Where do you think problem is ?
Do you think its fuel pump or fuel filter or something else?
Add to vikasevan's Reputation
Rate the quality of this post and help vikasevan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
vikasevan is offline   Reply With Quote
Old 06-13-2018, 04:57 AM   #2
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
Default Re: 2005 Saturn ION misfire and it sputters
Is your check engine light on? If so, get your car scanned for codes and post them here.
Without knowing anything else, I suspect that your catalytic converter is plugged. You can temporarily remove the upstream oxygen sensor to see if it runs any better. If it does, the converter is definitely plugged.
2007 Ion 2 Quad Coupe 5-speed manual 179K miles
2007 Chevy Equinox LT 190K miles
Add to ruley73's Reputation
Old 06-14-2018, 12:32 AM   #3
vikasevan
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Last time I checked it was misfire code ..nothing else but it was checked when sputtering problem was not there. After sputtering started ..I have not checked code ..neither I can because I dont have this car.. I am considering buying it.
You said cat convert but it is also possible ..it could be fuel pump or filter?
Old 06-14-2018, 03:02 AM   #4
ruley73
ruley73's Avatar
It's possible that the fuel filter is partially clogged or the fuel pump is weak, but it is far more likely that the catalytic converter is plugged. There's no way to tell for sure without further testing and troubleshooting.
Old 06-14-2018, 01:45 PM   #5
vikasevan
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
What are causes of misfire in this cars?
Seller already replaced spark plugs and coil pack?
how can I diagnose it?
could it be head gasket? or one cylinder is shot?
Old 06-16-2018, 05:06 PM   #6
ruley73
ruley73's Avatar
The ignition module is a part that commonly fails. Unfortunately, there's no way to confirm it's bad without replacing it.
2005 Saturn ion random misfire Duhminic Ion General 1 05-23-2017 11:16 PM
1995 Saturn SC2 sputters-dies freepam S-Series General 1 06-19-2015 06:35 PM
2008 Saturn Aura, sputters and when turned off wont start addiedaw Aura General 5 02-28-2014 10:20 PM
Vue 2006 2.2L - Sputters when accererating/ Misfire/ Fan on during a cold start: HELP Pluckahrot Vue General 21 02-12-2013 05:18 PM
Ion-1 2005, misfire 1 and 4 ohogset Ion Tech 10 01-20-2008 01:34 PM
