Old 06-06-2018, 07:34 PM   #1
jwright
jwright is on a distinguished road
Default brake fluid leak
I've got a 2007 Saturn Aura. The brake fluid light came on a couple of weeks ago. I noticed it was low on brake fluid and suspected a leak. So I added some fluid and planned to check the car in a few days. Well, I went on a trip and then it rained for a week in the afternoon and I forgot all about it. So the car sat for about two weeks. Today I noticed a large wet area under the drivers side rear tire. It looks like the wheel and tire are wet. Based on what I've read, this looks like a bad rear wheel cylinder. Does that sound right? I haven't taken the wheel off to check. Thought I'd check here and see if this is a job best left for a shop before I got my tools out. Thoughts?
My guess is that the job can't be any harder than the "How to Replace Brake Wheel Cylinder in Your Car" Scotty Kilmer video on youtube.
Add to jwright's Reputation
Rate the quality of this post and help jwright reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jwright is offline   Reply With Quote
Old 06-06-2018, 08:33 PM   #2
Default Re: brake fluid leak
Rear brake drums or disc? Beware of Scotty Kilmer videos. There are always questionable videos if you're not fully aware of anyone without credentials to back up expertise in specific areas. Remember, if you follow anyone's advice from a video and run into problems, is that person going to reply to questions immediately? Same here on these public message boards but you can always bad mouth a member and complain to Charlie the admin to remove a member. Brakes are safety issues. If you do your own work, you assume all risks. Many here, myself included, perform all brake repairs on our cars and assume theses risks. Your choice to plunge ahead or pay someone that must back up their work with a warranty and any liability issues if their repairs fail and an accident, injury or death occurs from faulty repairs traced back to incompetence.
A genuine brake fluid leak is a major repair. Beware of everything necessary for a successful repair. You can always remove a tire and examine the area of leakage to assess what repairs are needed, no different from any shop getting a customer's descriptions then examining where a problem lies, assessing costs before informing the customer on a final bill. If you're familiar with brake repairs then by all means go for it.
Old 06-06-2018, 11:37 PM   #3
explorerbigjon
explorerbigjon will become famous soon enough
2008 AURA XE
*Brake Caliper*
All Saturn Auras including the other Epsilon platform cars came with 4 wheel disc brakes.
Either the caliper is leaking fluid, or the hose is leaking fluid, or both. Check the fitting of the hose to the caliper, it is possible the sealing washers have sprung a leak. The bleeder valve on the caliper may also have come loose and is allowing fluid to leak. Much easier to replace the caliper and hose than a wheel cylinder.
I would take the time to inspect the other parts of the brake system just to make sure there is nothing corroded or damaged and could possibly cause another leak or failure.
2008 Saturn Aura XE 3.5-Sport tuning T10 wheels-Dynomax bullet/Borla ProXS-eBay intake-Pioneer Premier 12 shallow mount/Kicker CXA600.1
Upgrades coming!
Add to explorerbigjon's Reputation
Rate the quality of this post and help explorerbigjon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
explorerbigjon is offline   Reply With Quote
Old 06-09-2018, 09:46 AM   #4
jwright
You were right about the caliper leaking. I decided to take it to the shop. Thanks for the help.
Brake Fluid leak 97sl2DOHCaut1.9 S-Series Tech 14 07-01-2011 10:42 PM
Brake Fluid Leak coors S-Series Tech 1 03-06-2010 08:55 PM
Brake fluid leak, fluid container connection to master cylinder - PIC deegee S-Series Tech 8 08-13-2009 04:20 PM
stop brake fluid leak green S-Series Tech 1 02-13-2008 01:42 PM
Urgent...Brake Fluid Leak...Help!!! gladstone S-Series Tech 7 03-14-2005 07:08 AM
