#1 | ||||
![]() Join Date: May 2018
![]() my water temperature is climbing to a 3/4 of H at high speeds but stays at 1/2
in neutral and 4k rpm. I changed my sparks, oil, flushed water coolant it was pretty rusty. I usually feel the engine heat when testing it with my hand over the open window at the traffic lights but it just doesn't feel as hot as shown on temp dial, so heat is not dissipating as it should according to my "palm sensor" it is not the fan. the fan is good and blows 100% no engine errors other than silly random traction thing, I guess one of my rims is bent a bit. I took the radiator cap off and I see some flow so water pump is not completely dead yet. I checked the belt and pully it weeps more than it should but I don't think is the culprit. It must be the water pump bearing or blades, I just can't find any other good reasons that would explain sudden rust in the water I flushed my radiator last week and the water is getting brownish again. I walked into AutoZone and all they had was valucraft. Can anyone recommend a good water pump for my car, I don't like to be cheap when it comes to the cooling system. its XR 3.6 type 7 I can't wait too long either cooling is serious stuff. many thanks to all of you, David. ps: I love the XR, 10 years old and pulls 0-60 in 6 sec anytime.
#2 | ||||
![]() If the water pump weep hole shows signs of coolant, its time to replace it since coolant is flowing thru the bearings, rusting it from within. Did you try rockauto.com for a list of pumps including oem?
#3 | |||||
![]() Quote:
ill slide under the car this weekend and listen to it maybe record it with a snake cam that attaches to my phone. Ill think ill go with Ac Delco and use original bolts if the included ones are longer, gotta make sure the seal is ok. Does rockauto use a GM catalog for parts? Ill message them tomorrow. their prices are good and It looks LIKE the parts are a good match I can wait a few days to have it delivered.
#4 | |||||
![]() Welcome to SaturnFans, ddb!
I've seen no evidence of that. I'm reasonably sure that, in this case, the information comes from the AC-Delco catalog. You, of course, may visit any GM OE parts website of your choosing. I like the following, but there are more. https://www.gmpartscenter.net/ https://www.wholesalegmpartsonline.com/ ... 302,000 miles - Holy canolli! The blessings of liberty erode in my country. Gov't's grown bigger, but a chance exists that it will be reduced. I'm cautiously hopeful.
#5 | ||||
![]() Join Date: May 2012
2008 AURA XE
![]() One of the tell tale signs of water pump failure on these cars. While you're in there with the water pump, replace the thermostat as well.
GM wont admit it, but Dexcool anti-freeze/coolant is quite possible some of the worst quality in the market. The formula rots and ruins the metal in the water pumps, thermostats and sometimes in the engines themselves. ... 2008 Saturn Aura XE 3.5-Sport tuning T10 wheels-Dynomax bullet/Borla ProXS-eBay intake-Pioneer Premier 12 shallow mount/Kicker CXA600.1 Upgrades coming!
#6 | |||||
![]() Quote:
From now on, I will check my cooling pH and flush my system with vinegar just like I do on my espresso machine. vinegar water at 55-60C should take care nano rust and lime buildups that alter the ph. It doesn't get cold here, so I will use plain water from now on ill adjust ph to 8+ provided there are no alloy or aluminum parts in my cooling system. if there are alternatives, ill try to eliminate aluminum from my cooling system. I am not allowed to post links but you can google "Importance of the pH Value in Engine's Coolant" most say it is wise to avoid cooling liquid ph below 8 because of its corrosive nature and avoid pH and higher than 9 if you have alloy or aluminum in your system. I am making sure there are no aluminum composites in my cooling system so can use plain water, also, water absorbs more heat than antifreeze. my friend says he uses whole foods alkaline water in his system and its ok. I am not sure if that's wise. in any case, ph test kits are easy to get I used an API fish kit from Petco. Personally, I think money is better spent on a good water pump than frequent fancy antifreeze changes. it's nothing but dyed glycol anyway.
changed water pump by removing pump first | tataat | S-Series General | 0 | 09-09-2006 09:39 PM |
Need quick help - replacing power steering pump and water pump on V6…. | Emanresu2 | L-Series General | 6 | 05-18-2006 05:38 PM |
Water Pump | RalliArt16 | S-Series Tech | 9 | 05-11-2005 10:18 AM |
93 SL1 water pump | 93SLSuperTurd | S-Series Tech | 9 | 12-01-2004 10:52 AM |
water pump | 92saturnsl2 | S-Series Tech | 4 | 11-09-2002 12:50 PM |
