Old 05-31-2018, 11:02 AM   #1
CruzzieQ
CruzzieQ is on a distinguished road
Question Radiator Fan? Transmission cooler? 08 Astra H
Hi everyone ... does anyone know at what temp does the rad fan cut in on a 08
Astra H 1.8 auto?
Have had car for 2 months and have not heard the fan cutting in. i have had the water pump, timing belt , serpentine belt replaced, spark plugs replaced,
and tranny fluid changed Also any instructions on purchasing a tranny cooler and its install?
Thanks for your replies
Add to CruzzieQ's Reputation
Rate the quality of this post and help CruzzieQ reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
CruzzieQ is offline   Reply With Quote
Old 05-31-2018, 07:03 PM   #2
Default Re: Radiator Fan? Transmission cooler? 08 Astra H
1-Try googling Astra forums, overseas. One site, http://www.astraownersnetwork.co.uk/.../t-142561.html, seems to answer your question - fan turn on temperature around 108C/226F. That's close to Ions with two cooling fans, low speed cooling when temps reach 106C/223F, high speed cooling when temps reach 110C/230F.
2-Does your Astra have a digital temperature display? If not, a reader can display operating temps before cooling fan turn on temp in everyday driving.
All vehicle cooling systems operate by pressurizing it. In combination with a mixture of antifreeze and water, coolant under pressure won't boil until reaching approximately 129C/265F. Plain water boils at 100C/212F but in a pressurized cooling system, boiling point is raised much higher. For every pound of pressure increase, the boiling point goes up 3F. Typical radiator cap pressure is 12 to 16 psi. This raises the boiling point of the engine coolant to about 250F to 260F. Cooling fans are always turned on well below maximum boiling points.
3-One way to determine if the cooling fan failed or not; if your ac still works, turning it on should power up the cooling fan - its needed to force air thru two radiators (low to moderate car speed) the ac condenser coil and radiator. Both become warm to hot in summer weather so fan cooling is turned on whenever ac is used.
Old 05-31-2018, 09:00 PM   #3
CruzzieQ
Thanks fdryer, I do have the digital dash one which reads 73 degrees, and when, I turn the key on( not running ) the operating temp is 90 degrees.
So I guess I, will have to wait ... it should come on @ 106 to 110 degrees
Thanks again
saturn 96 sl1 radiator , transmission cooler line mr96saturnsl1 General Saturn Discussion 1 07-14-2015 10:07 PM
Small transmission fluid leak from radiator transmission cooler line EvanVanVan S-Series Tech 5 10-13-2014 07:55 PM
Transmission cooler/radiator bypass? XRL Vue Mods 13 08-20-2011 04:51 PM
Transmission cooler/radiator replacement when transmission is bad? infinitewisdumb S-Series Tech 2 04-16-2010 09:59 AM
S-Series Radiator replacement w/ Transmission Cooler Luke S-Series Tech 14 12-22-2006 01:12 PM
