Old 05-26-2018, 08:07 PM   #1
Xenergx
Xenergx is on a distinguished road
Default 2000 sl2 starts up than stalls
My gf has a 2000 sl2 that I've been doing some work on and theirs a reoccurring issue that pops up sporatically where the car fires up and than dies almost immediately.
I've replaced spark plugs/spark plug wires
Fuel pump/ fuel filter/ fuel pressure sensor
Replaced ECTS
Cleaned the egr valve
No service engine lights come on or anything
When she starts it she waits for the security light to stop blinking....
I'm kinda starting to draw a blank any help be appreciated. Thank you
Add to Xenergx's Reputation
Rate the quality of this post and help Xenergx reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Xenergx is offline   Reply With Quote
Old 05-26-2018, 09:35 PM   #2
Default Re: 2000 sl2 starts up than stalls
Were there any mods done for security?
Security should be off during starting. Security blinks when enabled with remote to Lock doors, off when using the remote to Unlock doors. Flashing during starting means security detected a theft attempt and disables injector operation; starter operation isn't affected - the engine will turn over but the engine will never fire up. Tamper mode may have occurred where starting occurs for a second then shuts off. Passlock is GMs factory theft deterrent system.
Try turning ignition ON and wait 10 minutes for security to reset. Cycle ignition off before trying a restart.
Old 05-26-2018, 10:29 PM   #3
Xenergx
No mods have been done ....the only thing she has is an aftermarket stereo. She doesn't have a key Fob she pushes the lock button before she leaves and uses the key to unlock the door.
Random Stalls and No Starts ckrysler S-Series Tech 9 09-25-2014 09:41 PM
L 200 starts then stalls goongreen L-Series Tech 7 05-10-2014 02:00 AM
2000 LW2 starts and stalls. Press Pedal RPM rises and drops Jessepatt8 L-Series Tech 13 04-30-2013 10:27 PM
SL1 Starts then stalls right out XsmallsX S-Series Tech 7 11-24-2011 07:35 PM
SL2 Starts Then Stalls jmap S-Series General 2 12-02-2007 02:18 AM
