Old 05-26-2018, 04:15 PM   #1
SalemCat
SalemCat will become famous soon enough
Default Overheated & STOPPED !
My 98 SW2 needs new Front Brake Pads, so I've set it aside for a couple of weeks.
I try to run it for 1/2 hour or so, every week, even if I am not driving it.
Today I started it, and came back 1/2 hour later. It was not running, and coolant was running down the street.
I added water, which immediately poured back out of the Left Bottom (drivers side) of the Radiator.
Then I started it, just to see. It started fast and seemed to run fine, for the 30 seconds or so I let it.
Can I just replace the 5-yr old radiator, and hopefully get through this ?
Add to SalemCat's Reputation
Rate the quality of this post and help SalemCat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SalemCat is offline   Reply With Quote
Old 05-26-2018, 04:40 PM   #2
Default Re: Overheated & STOPPED !
New radiator is the first thing to try.
Old 05-26-2018, 05:03 PM   #3
SalemCat
I have replaced four or five of these Radiators. They are pretty much a consumable.
The first time will be horrendous, due to the Transmission Cooling Lines being frozen in place.
But lube up the new ones, and next time is no sweat.
Could the engine possibly be undamaged ?
PS
Saddest thing is, my 1996 SW2 with a Radiator from 2012 just started leaking this week. I figured I'd throw some brake pads on the 1998, and be good for a month or two. Then today 1998 SW2 loses its 2013 Radiator !!
I'd be a lot more pissed, but honestly, I am thankful this happened in May and not February.
Old 05-26-2018, 07:13 PM   #4
It is likely it is fine but the only way to find out is to replace the radiator and run it. You may have sprayed hot antifreeze on the coils etc and that shut it off.
Old 05-26-2018, 11:22 PM   #5
billr
billr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of light
Try rotating the crank by hand, to be sure it hasn't seized from the over-heat. That is not a likely problem, but it is very easy to try rotating the engine; no use throwing a new radiator at it if the engine is toast.
Add to billr's Reputation
Old 05-26-2018, 11:28 PM   #6
SalemCat
It starts and runs as if nothing ever happened.
Of course I only drove it around the block, so it did not get even warm.
I'm shocked.
Old 05-27-2018, 12:45 AM   #7
Vaporized antifreeze and water shut the engine down.
Old 05-27-2018, 11:42 AM   #8
billr
Sorry, I missed that you had already started it again!
Old 05-27-2018, 11:46 AM   #9
SalemCat
So - the shutdown was most likely Electrical ?
Old 05-27-2018, 06:41 PM   #10
That stuff does not burn so the engine ran out of air. Generally that sets a P1599 code which does not turn on any lights. The air intake is real close to the left end of the radiator.
03' L200 AC stopped, then Temp Gauge stopped. Jon.Stokes L-Series General 3 06-21-2015 07:36 PM
I think it overheated. blue92 S-Series General 1 07-19-2013 08:57 PM
Overheated Grungi Aura General 3 05-19-2012 05:23 AM
Fan stopped working after engine overheated. 75DollarCar S-Series Tech 3 05-08-2010 03:15 PM
OVerheated Again! MSGJVH S-Series Tech 26 10-16-2002 03:17 PM
