Old 05-24-2018, 10:15 AM   #1
dancehatten
dancehatten has a spectacular aura aboutdancehatten has a spectacular aura aboutdancehatten has a spectacular aura about
dancehatten's Avatar
Default how to remove mangled oil filter
Any suggestions? I'm down to hammer and screwdriver, wd40 and a blowdryer, needlenose pliers, with no movement at all.
Does anyone know the name of that claw ratchet that fits into the holes on the filter, or where to get one?
Thx.
Add to dancehatten's Reputation
Rate the quality of this post and help dancehatten reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dancehatten is offline   Reply With Quote
Old 05-24-2018, 10:36 AM   #2
Nekomimi
Nekomimi is on a distinguished road
Nekomimi's Avatar
1996 SL1
Default Re: how to remove mangled oil filter
Maybe a spanner wrench would work?
'96 SL1 Originally the family car, passed on to me as my first. "Hellcat" 240,000+ miles and purring smooth.
My Mug is filled with the lost souls of imports.
Add to Nekomimi's Reputation
Rate the quality of this post and help Nekomimi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Nekomimi is offline   Reply With Quote
Old 05-24-2018, 11:39 AM   #3
Waiex191
Waiex191's Avatar
Ye Gods! I would probably make a custom spanner out of steel.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 05-24-2018, 01:04 PM   #4
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
Harbor Freight oil filter vise grips...
https://www.harborfreight.com/lockin...nch-66568.html
Mobil 1 ESP 0W-30, NAPA 41516...
NGK BKR6E-11 spark plugs
Old 05-24-2018, 01:08 PM   #5
How did that happen?
Pic of the wrench I use in this thread
http://www.saturnfans.com/forums/sho...d.php?t=195822
Not sure if you can fit it on what's left there . . .
Old 05-24-2018, 03:06 PM   #6
dancehatten, you need something like a spanner wrench or equivalent with a little imagination. If tapping on the holes doesn't unscrew it then maybe sticking a large needle nose plier tips into two holes can work. With the two tips inserted into holes on opposite sides of this mess, holding it in place and using your other hand to apply a vise grip onto the pivot part of the needle nose plier will become a spanner wrench..........
Old 05-24-2018, 06:58 PM   #7
JerryHughes
JerryHughes's Avatar
1997 SL
Here's one I really like. Like a pair of jaws.
Old 05-24-2018, 07:16 PM   #8
Please correct me if I'm wrong but isn't the OPs picture showing the remains of a destroyed oil filter with only the bottom threaded onto the fitting? If so then there isn't a filter wrench in the world to grab the oil canister that isn't there to grab.
Old 05-24-2018, 07:35 PM   #9
JerryHughes
1997 SL
Old 05-24-2018, 08:22 PM   #10
You will have to find a pin spanner that is a square drive so you can use an extension so you can get a breaker bar on what is left. You will probably have to make it yourself or find someone who can make it. All of the common spanners are not going to work and banging on this with a hammer and other tools is obviously failing and will continue to fail. If you gouge the block surface that the rubber seal sets onto that will likely end up destroying the block.
Old 05-24-2018, 08:24 PM   #11
That is exactly what has to be done.
Old 05-24-2018, 09:26 PM   #12
Mark_b
Mark_b is a jewel in the roughMark_b is a jewel in the roughMark_b is a jewel in the rough
What brand of folder was that?
I hope you gst it off.
Good luck.
Add to Mark_b's Reputation
Rate the quality of this post and help Mark_b reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mark_b is offline   Reply With Quote
Old 05-25-2018, 01:25 AM   #13
VUEmaniac
VUEmaniac is a jewel in the roughVUEmaniac is a jewel in the roughVUEmaniac is a jewel in the roughVUEmaniac is a jewel in the rough
I would CAREFULLY use an air chisel. With a corner of the chisel stuck in one of those holes, a couple of taps on the trigger will probably get what's left of the filter to spin off the threads. Just be careful to not gouge the mating surface under the filter carcass or the new filter may not seal properly.
Best,
All governments suffer a recurring problem: Power attracts pathological personalities. It is not that power corrupts, but that it is magnetic to the corruptible. -Frank Herbert-
Add to VUEmaniac's Reputation
Rate the quality of this post and help VUEmaniac reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
VUEmaniac is offline   Reply With Quote
Old 05-25-2018, 07:16 AM   #14
toggenburg
toggenburg's Avatar
Lots of good suggestions, but, If this was my car, I would use a simple pair of Channel lock pliers and go right on the remaining aluminum thread-hub.
There is enough of the filter aluminum to grip and turn off the stainless steel hub without any tool damage to the steel hub.
A twist of the wrist and the filter skeleton would be loosened.
Some manufacturers call the tool 'water pump pliers' but they are a simple tool (tongue and groove/ratcheting jaw) found at Lowes/Home Depot, etc.
https://www.lowes.com/pd/CHANNELLOCK...iers/999914685
Old 05-25-2018, 08:19 AM   #15
Highmile
Highmile's Avatar
Doesn't the threaded part just screw into the back of the block. I believe the inside is a hex so an allen wrench in there should unscrew the entire mess from the block
once unscrewed from the block you can take it apart on the bench
Highmile
'95 SL1 658k and counting
Add to Highmile's Reputation
Old 05-25-2018, 08:55 AM   #16
You'd have to grab that base with the wrench, going in straight instead of the side like normal
Spanner would be best but sometimes you are limited to what you have on hand. It looks like he has already chipped away at the right side of the base with a screwdriver.
Maybe removing that large U-shaped bracket might help with access. Have to support the engine though (underneath with a piece of wood on top of a jack, to protect oil pan)
never tried this but if you get really desperate, wrap a bit of clean rag around a screwdriver (to protect the surfaces) and see if you can bend the lip of the filter base away from the mounting part. Keep the tip of the screwdriver away from the contact areas. Most likely the friction of the metal base on the mounting section and the rubber gasket is what is making it hard to turn.
In a moment of weakness, I got an oil change at Walmart once and almost had the same situation. The oil filter was manhandled on so tight the metal of the canister base scored and dug into the metal the mounting area. Screwdriver through the case just ripped the case. Strap wrench just crumpled it.
you're gonna want to clean all that oil off that axle boot afterwards, too
Old 05-25-2018, 10:35 AM   #17
dancehatten
Default Re: how to remove mangled oil filter SOLVED
Finally . . . three days later and using all of your suggestions, it is off.
-Propped up the engine and remove the engine mount bracket out of way,
-Slid the driver in around the edge to pry it off the surface,
-Allen wrench to loosen the mounting bolt until it turned freely both ways,
and
-Needle nose with driver between handles and TURN, hard.
I will now frame it and mount it in the shop as a reminder of what NOT to do.
Thank you all so much, D.
Old 05-25-2018, 10:46 AM   #18
Waiex191
Waiex191's Avatar
Well done! Anybody can do it right the first time, but to fix a screwup takes real skill. I've been in that corner more than once!
Bryan Cotton
Old 05-25-2018, 11:32 AM   #19
Some of those do not have the inner hex so you can get them loose that way. Your earlier pix did not show that clearly as if that exists it is the easy-off method.
Old 05-25-2018, 11:32 AM   #20
Fantastic, happy ending to start off the weekend
lol, now I feel better about the time I spent removing the Walmart tech's screwup of my filter.
should I feel a little bad that I do it right the first time?
Since anyone can do it
(and apparently, not everyone can do it right the first time, as the oil filter in the pics attest to )
Which way to turn to remove oil filter jcc007 Vue General 8 12-20-2011 08:50 AM
Trick to remove oil filter? cash70 Vue General 12 11-05-2010 06:35 AM
Mangled Locator Pins ChiliPepperSC2 S-Series Tech 5 12-06-2008 03:24 PM
Help!! Can't Remove Oil Filter on a 96 SC2 rmlimage S-Series General 20 09-19-2006 12:05 PM
How To Remove The Oil Filter On a 3.5L? Bullet Vue General 16 06-28-2005 05:45 PM
