Old 05-23-2018, 06:20 PM   #1
LPmailman
LPmailman is on a distinguished road
Default Interchangeable Parts?
I need to put a new rack and pinion on my right hand drive 1999 Saturn SW1. I was given the part number by a dealership but the part is discontinued. They recommended I check aftermarket parts. Auto Zone has the part but can't tell me if it is only for left hand drive, only for right hand drive or if it will fit both. Does the same rack ad pinion part fit both right hand and left hand drive? Or is there a specific part for right hand drive only?
Add to LPmailman's Reputation
Rate the quality of this post and help LPmailman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LPmailman is offline   Reply With Quote
Old 05-23-2018, 07:04 PM   #2
onlinebiker
onlinebiker is a glorious beacon of lightonlinebiker is a glorious beacon of lightonlinebiker is a glorious beacon of lightonlinebiker is a glorious beacon of lightonlinebiker is a glorious beacon of light
Default Re: Interchangeable Parts?
Pretty sure the postal version is different from the left hand drive.
You probably are going to do a fair bit of searching.
You might try junkyards in countries where they drive on the left.
Good luck..
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
3 96 SC2
Old 05-23-2018, 08:21 PM   #3
Check here:
https://www.detroitaxle.com/
https://www.turnone-steering.com/pag...lding-services
You will get the info you are looking for. And check on Amazon as several sources list there as well.
Old 05-25-2018, 08:23 AM   #4
Highmile
Highmile's Avatar
Can yours be rebuilt?
Is it something where it just needs new seals?
Highmile
Add to Highmile's Reputation
Old 05-25-2018, 03:35 PM   #5
2NDSOUT
2NDSOUT's Avatar
1999 SL
You may want to check www.saturnautosalvage.com in Kansas
They only specialize in Saturn S-Series cars. I have bought from them before, they may have parts for the SWP as well.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Add to 2NDSOUT's Reputation
Old 05-25-2018, 06:14 PM   #6
Macgyver
Worse case, you could remove the rack and have someone rebuild what you give them.
Add to Macgyver's Reputation
Old 05-25-2018, 08:49 PM   #7
No one actually rebuilds them. You find good ones in the JY as it is cheaper.The RHD rack is available from the links I posted.
Old 05-25-2018, 09:42 PM   #8
toggenburg
toggenburg's Avatar
^^ Old Nuc, your first source link (Detroit Axle) only differentiates the '99s as SW1/SW2, but not SWP. So were the RHD models all SW1's?
The second choice does say they rebuild a customer's rack.
Old 05-25-2018, 11:09 PM   #9
RHD wagons were SW1's with the driver sitting on the wrong side of the car, which probably led to a unique steering rack and funky brake pedal setup that they didn't feel like replicating for the clutch so SWP's were only automatics (not sure if all RHD's were auto-only but probably)
Old 05-25-2018, 11:43 PM   #10
Zeebins
Zeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to all
Zeebins's Avatar
Based on photos I've seen online they didn't feel like making a new gear selector with the button on the right so they just used the one from a manual that had no button
Road salt will be the death of me
1997 SL2, 112K miles
Add to Zeebins's Reputation
Rate the quality of this post and help Zeebins reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-26-2018, 03:31 PM   #11
bumpdraft
bumpdraft's Avatar
1998 SW2
One thing in favor of having Turn One rebuild your steering is that your system uses the part of a rack gear like no other. You could request that a flipped-over rack gear from a LHDrive be substituted for your well-worn rack gear. You might even have such luck with the pinion gear. The people at Turn One would sure be the ones to know.
Iíd guess that parts that take a pounding on these Rack & Pinions are the bushings that guide the rack gear. I imagine a postal wagon driven on wash-boarded dirt roads would be tough on bushings. If the bushings have slop in them, the gear teeth would fret more than usual.
Competition Clutch 10Lb. Flywheel. 14 stalls to date (and loving it)
Add to bumpdraft's Reputation
interchangeable parts camille8473 S-Series General 10 09-22-2013 03:00 PM
interchangeable parts Scott Peterson S-Series General 1 05-09-2008 06:12 PM
Which parts are interchangeable? actionplant S-Series Mods 4 10-07-2006 04:44 AM
Interchangeable parts? DBR-Saturn Miscellaneous Tech 2 11-13-2003 11:18 PM
Interchangeable Parts KoolVue Vue Tech 1 04-13-2002 03:26 AM
