Old 05-22-2018, 07:20 PM   #1
BobWolf
BobWolf will become famous soon enough
Default Head and block compatability
Down the rabbit hole I went. Last fall I started a project rebuilding my daughters 2007 Ion 2.2 engine.
I opted to do an inframe rebuild. I’ve done this several times on cars and trucks without an issue. The most important thing is keeping everything clean.
Although it was time consuming all went fairly well until the moment of truth. I fired it up it idles and runs smooth as glass and it drove wonderful…… About six miles into the test drive I heard death knocking from the lower end.
Sure enough I found a low spot on the #1 rod journal. I had a local engine shop tell me to swap in a different engine due to it being almost impossible to get all the metal out of the oil galleries.
I have a 2.2 from another vehicle; sitting side by side with the exception of the heads they look pretty much Identical, smog pump, intake, exhaust, engine mounts, ETC. but it has the single coil pack on it instead of the individual coil on plugs and ths power steering pump omitted.
Are the blocks and internals identical and can I simply switch heads? I know the cam / crank sensors are one is in the head the other is in the block. The head I’m keeping the sensor is on the head.
We are all born ignorant, but one must work hard to remain stupid.
Benjamin Franklin.
Add to BobWolf's Reputation
Rate the quality of this post and help BobWolf reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BobWolf is offline   Reply With Quote
Old 05-22-2018, 08:44 PM   #2
Waiex191
Waiex191's Avatar
Default Re: Head and block compatability
Bob,
I recommend replacing the whole thing with an S Series. All kidding aside, there are Ion forums here too and they probably know the answers.
S Series cars are awesome though.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 05-23-2018, 09:29 AM   #3
Saturn Night
www.car-part.com
Source a used engine, and make sure to install a new timing chain kit before swapping into the Ion.
You have to watch Ion Eco-Tecs because much like our Saturn S-Series, there were revisions(minor changes) over the years of Eco-Tec production.
An L-Series Eco-Tec, for example, would fit into an Ion and bolt up to the transmission, but it wouldn't likely run due to all the internal/electrical differences.
Car-Part uses Hollander Interchange, which is as close to direct-swap interchange as you will get. Hollabder uses the information supplied by manufacturers and cross-references the part numbers.
2007 may only fit a few years, and older Ion engines may not work.
Saturn Night is online now   Reply With Quote
Old 05-23-2018, 09:57 AM   #4
trottida
trottida's Avatar
You can post this question in the ION forums which are linked below. This area is part of the S Series forum which include the 1991-2002 model year S Series coupes, sedans and wagons.
http://www.saturnfans.com/forums/forumdisplay.php?f=18
Past Saturns
1993 SW2 AT
2001 LW200 MT
1992 SL2 MT
:canada:
Add to trottida's Reputation
Head and block compatability BobWolf Outlook General 1 06-21-2018 07:14 PM
Head and block compatability BobWolf L-Series General 0 05-22-2018 07:15 PM
Head gasket? Cracked head / block? Paranoia? reverser S-Series Tech 2 04-16-2014 10:11 PM
2nd gen head, 3rd gen block remedys S-Series Mods 2 06-04-2006 11:45 AM
Help!!!! Head Swap Compatability?? SL2PIMP S-Series Tech 8 08-02-2003 06:41 PM
