Old 05-21-2018, 09:28 PM   #1
Thruxtonup
Thruxtonup has a spectacular aura aboutThruxtonup has a spectacular aura aboutThruxtonup has a spectacular aura about
2002 SL1
Default Automatic transmission on the fritz when warm
I have an 02 sl1 with just over 100k. I'm not sure if the trans was rebuilt at some point, but it throws codes that reference the gear ratios being wrong and slips going into second. But the major issue is, if it's hot out and I sit at a red light for too long it will refuse to shift out of first until I shut the car off and restart it at least once. Any suggestions would be greatly appreciated!
Add to Thruxtonup's Reputation
Rate the quality of this post and help Thruxtonup reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Thruxtonup is offline   Reply With Quote
Old 05-21-2018, 09:39 PM   #2
billr
billr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of light
Default Re: Automatic transmission on the fritz when warm
Is this car new to you, or is this a new problem? Post the actual code numbers.
If the car is new to you, check the S/N on the trans, let's make sure it is the correct version for your engine/PCM.
After that, it is time to get set up to view live-data; that can avoid a whole lot of guessing and parts-swapping.
Add to billr's Reputation
What relays control the transmission shifter on an automatic transmission kd183 L-Series Tech 1 02-25-2014 11:13 AM
Slow Acceleration, Transmission Starts in 2nd Once Warm larrytxeast L-Series General 1 08-25-2009 06:46 PM
Hesitation when warm. Transmission P0133 ebristol S-Series Tech 10 03-26-2007 12:52 PM
vue gas gauge on the fritz maynardf1 Vue General 3 08-20-2002 01:15 PM
