Old 05-21-2018, 12:00 PM   #1
JerryHughes
JerryHughes's Avatar
1997 SL
Default Headlight "fog"?
Hi all Saturnites,
I haven't been having a big problem with that "haze" or white "fog" that gradually forms over the clear lenses of my headlights but have a question about preventing it. It's light enough where I can remove it with just some rubbing with a wet rag and toothpaste. After cleaned off, it stays off for a while but eventually returns. Since I'm going to be touching up my paint on the car and top coating that paint with a glossy seal, if I spray that glossy seal over the headlight lens, anyone know if that will keep the haze off them for "years"? Thanks for any valued experience with this.
Old 05-21-2018, 02:10 PM   #2
Zeebins
Zeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to all
Zeebins's Avatar
Default Re: Headlight "fog"?
I haven't done it myself yet but my plan for restoring my headlights is various levels of wet sanding and then finish with a clear coat. That's what I got from a YouTube video anyway
Road salt will be the death of me
1997 SL2, 112K miles
Add to Zeebins's Reputation
Rate the quality of this post and help Zeebins reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-21-2018, 02:57 PM   #3
hholbein
1997 SW2
You can buy a replacement pair of headlights with bulbs for <$50 delivered on Amazon. I was thinking that would be a lot easier than wet sanding/recoating the lenses.
Anyone given these a try? I was thinking about trying a replacement pair sometime this year.
Add to hholbein's Reputation
Old 05-21-2018, 03:23 PM   #4
TXsaturn02 tried some
http://www.saturnfans.com/forums/sho...d.php?t=192602
Old 05-21-2018, 06:03 PM   #5
JerryHughes
1997 SL
Thanks, guys for the info. My current headlights aren't bad enough to replace, again, just some rubbing with toothpaste will remove the "fog". Just might try the spray clear coat. According to the clear coat spray can I have, it does protect for U/V. I'll clean them really well before spraying and hope for the best. Thanks, all.
"Fogged" headlight: best remedy? Tatohead S-Series General 50 07-30-2015 01:23 PM
Saturn S Series Photo Contest!- April- Car "Selfies" and "Twin Cars"!!! blackbeard S-Series General 18 05-04-2014 11:06 AM
99 SC1 Headlight and Rear lights go off when turned "ON" PackerBacker52 S-Series General 1 08-01-2012 01:31 AM
Vin "7" Vin "8" Vin "9" brake pads/rotors universal? demoncamber S-Series Tech 4 09-09-2009 12:35 PM
Tip on "hazy" headlight bezels---toothpaste JerryHughes S-Series General 13 09-24-2008 09:03 PM
