Old 05-20-2018, 02:34 PM   #1
jdarmo
jdarmo is on a distinguished road
2007 AURA XE
Default Auto Lock/Unlock
All of a sudden, the auto door lock/unlock feature on my 2007 Aura has stopped working. The driver info center says that the settings are correct, but still no go. Any ideas??
Jdarmo
Add to jdarmo's Reputation
Rate the quality of this post and help jdarmo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jdarmo is offline   Reply With Quote
Old 05-20-2018, 03:20 PM   #2
pstrick
pstrick is on a distinguished road
2007 AURA XE
Default Re: Auto Lock/Unlock
Jdarmo
Do you mean that the doors don't unlock when you put it in park?
Or does the lock button on the door no longer work?
Add to pstrick's Reputation
Rate the quality of this post and help pstrick reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
pstrick is offline   Reply With Quote
Old 05-20-2018, 09:22 PM   #3
jdarmo
2007 AURA XE
It won't unlock the doors when put into park and won't lock when I take it out of park.
Old 05-20-2018, 11:05 PM   #4
Checked for blown door lock fuses. Is there one main door switch that may be worn out and stuck or damaged, blowing a fuse?
Old 05-24-2018, 10:04 PM   #5
imaddicted2u
imaddicted2u is a jewel in the roughimaddicted2u is a jewel in the roughimaddicted2u is a jewel in the roughimaddicted2u is a jewel in the rough
2008 AURA XE
These conditions must be met for ADL to operate properly...
Your vehicle is programmed at the factory to lock all
doors automatically when the following are met:
All doors are closed.
The ignition is on.
The shift lever is moved out of PARK (P).
This feature cannot be disabled.
If there is no door ajar message showing it could be related to a bad ground or faulty PNP switch (although I would think that would throw a trouble code)
When the ground wire for the transmission side of the PNP switch became intermittent, I was able to lock/unlock the doors by wiggling the wiring harness, causing the ground to make and break.
See my post here for wiring diagrams and the ground lug location:
http://www.saturnfans.com/forums/sho...d.php?t=234451
Add to imaddicted2u's Reputation
Rate the quality of this post and help imaddicted2u reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
I cannot lock or unlock the doors using the key fob SaturnSL2Fan S-Series Tech 13 05-12-2017 01:31 PM
Auto lock/unlock issue... AJEsquire Vue Red Line 7 09-28-2012 06:51 AM
08 Random Lock/Unlock sparky912 Aura General 3 10-24-2011 04:44 PM
Lock/Unlock switch. Picsman S-Series Tech 0 06-30-2007 11:12 AM
Lock/Unlock Button fritzdog Aura General 1 10-09-2006 10:00 AM
