Old 05-20-2018, 01:12 PM   #1
James9
James9 is on a distinguished road
Default Dead trans solenoid
My mom has a 01 sc2. It had all of the symptoms of the bad valve body and loose input shaft nut. I picked up another valve body at lkq and it was replaced along with tightening the nut. It worked for awhile then the problems came back. Rechecked the nut and we got a VB from eBay, remanned with sonnex parts. This time the problems stayed. My brother started testing solenoids and found that one was dead, also got the same thing from the junkyard VB.
Looking at the connector from the harness, it looks like it's been burning, black and melted plastic. What could cause this? We were going to try replacing the plug on the harness and the solenoid, but would like to figure out why it keeps burning them up to start with.
Add to James9's Reputation
Rate the quality of this post and help James9 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
James9 is offline   Reply With Quote
Old 05-21-2018, 09:15 PM   #2
Tom Walsh
Tom Walsh is a jewel in the roughTom Walsh is a jewel in the roughTom Walsh is a jewel in the rough
2002 L-Series 2.2L Sedan
Default Re: Dead trans solenoid
When you have the Valve body apart, be sure to check the connector plate.. The holes the plate has for connecting the solenoid can be checked with a drill bit (Size #41 I think. Look in the threads. I know I posted the size but I'm not positive). If I owned those VB's , I'd throw away both pressure solenoids whatever they read and pick from the rest to make one complete set. Good Luck
Add to Tom Walsh's Reputation
Rate the quality of this post and help Tom Walsh reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tom Walsh is offline   Reply With Quote
auto trans solenoid question muddawg S-Series General 6 06-14-2017 12:30 PM
WTB -- TAAT Trans solenoid(s) bachands Classifieds 2 05-10-2015 12:22 AM
where is 00 LS2 trans. pressure solenoid? 00 SL2 L-Series Tech 7 12-18-2013 10:33 AM
Trans solenoid testing kingkevin8 S-Series Tech 3 04-16-2009 02:36 PM
trans. solenoid replacement kingralphie1 S-Series Tech 1 12-02-2008 09:17 PM
