Go Back   SaturnFans.com Forums > Models > Saturn Sky > Sky Red Line
Old 05-19-2018, 02:49 PM   #1
herp444
herp444 is on a distinguished road
herp444's Avatar
2008 SKY Red Line
Default Dead car battery. Now RKE does not work
I was doing some work in the garage and listening to music from the car. it was turned to ACC and I didn't think twice about it. a few hours pass and the music shuts off. I realize that hours had passed and the battery is dead, nothing works. I pull the key and get my battery charger. put it on a charge and when it was done it fired right up. I put everything away and go to lock it but the RKE does not work. unlock, lock, panic or truck. I checked the fuse in the underhood fuse panel and it's fine. what happened? do I need to go back to the dealer for reprograming or is there something that I need to do?
Add to herp444's Reputation
Rate the quality of this post and help herp444 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
herp444 is online now   Reply With Quote
Old 05-19-2018, 03:57 PM   #2
pierrot
pierrot's Avatar
Default Re: Dead car battery. Now RKE does not work
For starters, be sure that the battery in the RKE fob is good.
300,000 miles - Holy canolli!
Add to pierrot's Reputation
Old 05-19-2018, 08:30 PM   #3
If the rke battery checks out good, try disconnecting (car) battery negative for a minute then reconnect it. Sometimes electronics hang up. Disconnecting main battery power allows volatile memories to drain for a factory reset. Be prepared to hear the alarm in case it goes on and use your remote to shut it off.
Old 05-21-2018, 12:54 AM   #4
herp444
herp444's Avatar
2008 SKY Red Line
The fob batteries are good as I tried both fobs and different batteries. I'll try disconnecting the battery and see from there.
Old 05-23-2018, 06:25 PM   #5
herp444
herp444's Avatar
2008 SKY Red Line
it was a no go on the disconnect. no biggie I guess i'll just go to the dealer soon
Dead battery DJM1972 S-Series Tech 13 05-29-2015 02:40 PM
Need help with a dead battery! Twilson Astra Tech 5 01-13-2014 11:03 PM
Another Dead Battery... Tallboy Aura General 4 06-17-2008 05:43 PM
SL 94 - battery dead Pega_de S-Series Tech 7 04-24-2007 02:29 PM
Battery goes dead on LS1 after tow behind R.V. sattech L-Series Tech 0 03-28-2000 10:47 PM
