Old 05-19-2018, 01:52 PM   #1
Northerner
Northerner is on a distinguished road
2004 VUE 2.2L
Idea Question about shifting and pressure needed to push stick in/shift from gear to gear
I have two Saturn VUEs now and the one I just bought it is harder to push the stick shift into 1st gear and it's harder to push it in any other gear when shifting.
How do I know how hard it should be to press the actual shift nob into gear? Why would one be a little easier/cleaner than the other?
Does that indicate that the one that is harder to shift is "fresher"?
Or is the one that is easier to shift into/transition from gear to gear not supposed to be easier, and therefore a sign of a wearing transmission?
I have two of the same VUEs - both are manual transmission 2004 models.
Add to Northerner's Reputation
Rate the quality of this post and help Northerner reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Northerner is offline   Reply With Quote
Old 05-19-2018, 02:03 PM   #2
Default Re: Question about shifting and pressure needed to push stick in/shift from gear to g
Does it shift easier with engine off? Engine off; shifting without any effort, clutch engaged all the time. This checks the xmission only. With engine running, clutch must be disengaged in order to shift. Difficult shifting points to three things - clutch master and slave unit or clutch.
Old 05-19-2018, 03:05 PM   #3
waiter21
2003 VUE 2.2L
Shift cables are bad..
My "Rescue Vue" was hard to shift.. I put new shift cables in it and now its almost like a normal mechanical linkage shifter..
Look at this link:
http://www.saturnfans.com/forums/sho...d.php?t=217222
Add to waiter21's Reputation
Old 05-19-2018, 04:36 PM   #4
Northerner
2004 VUE 2.2L
About the same when the engine isn't running. Kind of "tough" to shift the gear knob into gears.
Old 05-19-2018, 04:38 PM   #5
Northerner
2004 VUE 2.2L
Look at this link:
So...not anything transmission related, per se??
Old 05-19-2018, 07:26 PM   #6
waiter21
2003 VUE 2.2L
cables..... You can try cleaning them.. but not sure how successful that is..
Old 05-19-2018, 07:38 PM   #7
Northerner
2004 VUE 2.2L
I'm sorry I'm not very car savvy.
Just to be clear, "cables" doesn't necessarily mean that the transmission/clutch is going bad?
I need to know because I am going to keep one of my Vues and I want to choose the one that needs the least amount of repairs (or serious repairs).
Old 05-19-2018, 07:52 PM   #8
waiter21
2003 VUE 2.2L
Tranny is probably OK. The problem is the shifter cables that connect the shift lever to the transmission. These cables are about 6 ft long, they get old and worn, then start binding and make it hard to shift.
The cables cost about $200 for the set. NOTE - I just seen some on e-bay for less than $100. The price must be coming downn..
Old 05-19-2018, 08:11 PM   #9
Same shift feel with engine ruining or not makes it a little more difficult to narrow the problem down. waiter21 seems to have good clue about worn shift cables.
Old 05-19-2018, 08:18 PM   #10
Northerner
2004 VUE 2.2L
Okay. Thank you for responding. It's nice when people add some decency to the world.
2000 SL2 Car won't shift into any gear, stuck in 1st gear? MyCarBroke S-Series General 3 11-26-2016 01:36 PM
Shifting problem - needs to take out the Gear Shift Assembly on the transmision MX-523 Support Forum for Canadian Saturn Owners 3 03-29-2011 12:45 AM
auto 95sw2 2nd gear doesnt fully engage until right before 3rd gear shift? kaptnjack S-Series Tech 4 01-06-2010 08:10 PM
98 SC 2 Question (Gear shift) nvshrs06 S-Series Tech 8 11-18-2007 12:47 AM
1999 SC2 (stick) - Will Not Shift, Stuck In 3rd Gear Apostle S-Series Tech 21 08-11-2005 06:28 AM
