Old 05-18-2018, 09:01 AM   #1
Alexandra1973
Alexandra1973 is on a distinguished road
Default Noisy liftgate
This started this past week (2002 Vue).
When the engine is running, I hear a humming/vibrating sound in the back. The liftgate is vibrating. I opened the liftgate while it was running--the vibration is coming from the liftgate. That is the only part that's vibrating/making that sound.
Any ideas? It eases up a bit as I drive. I don't know if this has anything to do with it, but the rear washer and wiper don't work.
Add to Alexandra1973's Reputation
Rate the quality of this post and help Alexandra1973 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Alexandra1973 is offline   Reply With Quote
Old 05-18-2018, 09:47 AM   #2
atikovi
Default Re: Noisy liftgate
Maybe check for missing rubber cushions on the body or the liftgate to start.
Add to atikovi's Reputation
Old 05-18-2018, 12:10 PM   #3
rb6667
rb6667's Avatar
2004 L-Series 2.2L Wagon
2004 L-Series 3.0L Wagon
^^^No doubt this was done while the car was Parked. This would indicate that something is loose in/on this panel.
Take a look at how the Interior cover is attached to the liftgate. You may find something as simple as a loose screw. These are usually under some plugs that you pull out to reveal the screws. Check all of those and make sure they are secure and tight.
It is also possible that the rear wiper and washer not working has something to do with this. Removal of that rear cover would verify if something has broken on these parts and is the culprit.
2004 L-Series Wagon 2.2
2004 L-Series Wagon 3.0
Add to rb6667's Reputation
Old 05-18-2018, 01:10 PM   #4
Alexandra1973
I have a manual transmission and the noise is there even while I'm driving. The noise stops the minute I turn the engine off.
I will check the panel. There are two lights at the bottom of the liftgate, on the interior, and I noticed one of them is out. Shouldn't be a big deal to fix that.
UPDATE: I think I solved the problem.
Last time I tried to run the rear wiper, it only moved about an inch, then stopped.
So...I ran the engine, had the noise again, went back, moved the wiper back to its "starting" position--and the noise stopped.
So yeah, something to do with that motor. Best to just leave it off. I like being able to run the back wiper, but given I don't have the money for repairs, it's low-priority at this point.
Need New Liftgate Glass cuetip S-Series General 3 12-23-2012 08:40 AM
Noisy wheel bearing or noisy brake pads? wscreate S-Series Tech 6 02-16-2012 06:10 PM
Vue's liftgate jita1 2008 Vue 4 08-08-2009 02:49 PM
Liftgate repo_man62 Vue Tech 1 11-01-2007 12:56 AM
Liftgate Air Deflector ? jeffkics Vue General 10 10-15-2004 11:57 AM
