Old 05-15-2018, 11:34 PM   #1
Zeebins
Zeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to all
Zeebins's Avatar
Default Took a gamble, bought a tech2 clone (Tech2Win)
About a week ago I added a cruise to my car but I needed the computer to be programed so it would actually work. I went to one chevy dealer that claimed they could do it but ended up not being able to. I then called 5 others in the area and none of them where able to (or wanted to) turn on cruise either.
I saw that Kaervak recently bought a Tech2 clone that looked liked it fully worked as a real Tech2. $300 is a little steep of a price to pay though for something I may only ever use for turning on cruise control. I did some searching around for some cheaper alternatives and I came across this on the Corvette forms, A Tech2Win adapter. It's essentially the software of a tech 2 running on a windows computer and connects to the car through either a USB or wi-fi adapter. It was $120 on amazon, a lot cheaper than a full hardware Tech2 clone and the dealers I was calling where somewhere around $120 for a minimum shop time charge, so it seemed worth trying out.
It was delivered earlier today and in the box was the OBD2 adapter, a micro usb cable, and a CD of software. The software it came with included, GM MDI Manager, VX Manager, Tech2Win, and VMPlayer. I installed all of them except for VMPlayer as it's only needed if you'll be running the other software from inside a virtual machine.
Once the software/drivers where finished installing, The Tech2Win software was able to recognize the adapter and connect to the car. After going though some menus I got to the option programing and was able to turn on cruise control. Went out for a test drive and I can confirm that cruise control now works.
This this is a pretty cool device and probably the most advanced scan tool i'll ever own. As far as I can tell, anything that a real Tech2 can do, this thing can also do. If anyone has any questions about the Tech2Win feel free to ask me
I've taken some photos and posted them to an imgur album as well as to an album on this site incase anything ever happens to imgur.
link to imgur album - https://imgur.com/a/mpaJxgn
Road salt will be the death of me
1997 SL2, 112K miles
Add to Zeebins's Reputation
Rate the quality of this post and help Zeebins reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-15-2018, 11:48 PM   #2
Default Re: Took a gamble, bought a tech2 clone (Tech2Win)
It is the MDI Manager that is required to make the tech2win actually communicate and is usually not included. This setup is probably a bit fiddly and user nasty for most shops/DIY types but if you have patience it will work.
What OS is running on your computer?
Old 05-15-2018, 11:53 PM   #3
Zeebins
Zeebins's Avatar
MDI manager was the only one I couldn't get to launch, it would always crash before it would open. Glad to know it's doing something. And yeah, no instructions whatsoever, defiantly not user friendly. I'm running windows XP, it just has a theme set to make everything black.
Old 05-16-2018, 12:03 AM   #4
RobertGary1
Can you add fobs to saturn vues or does that require tokens?
Where did you buy it?
-Robert
Old 05-16-2018, 12:25 AM   #5
Zeebins
Zeebins's Avatar
-Robert
I got it on amazon
https://www.amazon.com/gp/aw/d/B0743...o_pop_mb_pd_t2
As for fobs, based on this screen I was able to get to, I'd assume so.
Old 05-16-2018, 05:30 AM   #6
Mark_b
Mark_b is a jewel in the roughMark_b is a jewel in the roughMark_b is a jewel in the rough
I also looked at the clone but did not want to pay that much.
I saw this one on the Chevy Volt fourm. They use it to program modules and check battery pack voltages.
Mine will be here in a couple days. Thanks for posting. I want to use in to reset the transmission adaptive settings. Crank sensor position relearn. Do you see the relearn settings and clean transmission adaptive settings?
I also might try to program my son's Pcm.
Add to Mark_b's Reputation
Rate the quality of this post and help Mark_b reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mark_b is offline   Reply With Quote
Old 05-16-2018, 08:33 AM   #7
Kaervak
Kaervak will become famous soon enoughKaervak will become famous soon enough
Kaervak's Avatar
I thought about getting the VCXnano instead of the full blown Tech2 clone, but decided against it mostly because it requires a laptop. Still a very cool piece of hardware though. Glad to see its worked well for you and that it's viable alternative to a full blown Tech2 setup. Thanks for posting about it.
Add to Kaervak's Reputation
Rate the quality of this post and help Kaervak reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kaervak is offline   Reply With Quote
Old 05-16-2018, 09:13 AM   #8
If you reset the hard stored trans adaptives be sure to read the relearn steps for that specific set of adaptives before doing it as you have the potential to mechanically damage the transmission.
Old 05-16-2018, 09:17 AM   #9
I suspected you were running a 32 bit XP. many of these programs will not run on the latest versions of the OS. MDI might be 64 bit and that is why it crashes. Some of these programs are actually a compiled VMWare image that is running in a VM.
Old 05-16-2018, 10:17 AM   #10
RobertGary1
Do you also have to buy a tech2win subscription?
Old 05-16-2018, 10:40 AM   #11
Mark_b
You only have to buy subscription to program modules.
They now have a $40 for one car for 2 years. (This lets you program modules for one VIN)
https://www.acdelcotds.com/acdelco/action/subscribehome
Old 05-16-2018, 11:06 AM   #12
Zeebins
Zeebins's Avatar
I did see an option to relearn crank position. I don't remember seeing one for transmission adaptive settings but I also wasn't really looking for it but I'd assume it's there without having to check
Old 05-16-2018, 12:03 PM   #13
It should be there if you have an automatic.
Old 05-16-2018, 12:53 PM   #14
RobertGary1
That makes sense that they are emulating whatever OS the Tech2 hardware runs internally so they don't need to port the app.
-Robert
Old 05-16-2018, 01:15 PM   #15
This post: http://www.saturnfans.com/forums/sho...1&postcount=11 gives you an idea of the size of the soup sandwich,
Old 05-16-2018, 01:23 PM   #16
Mark_b
I dug out my old win7 laptop and I and charging it and getting updated.
It has 125 updates to do
I had to go back four laptops to find a 32bit laptop. Mine gets delivered tomorrow.
Old 05-16-2018, 01:44 PM   #17
Mark_b
Here are a couple videos of the software in action put out by VXDIAG
VXDIAG GM Tech2win diagnostic
https://www.youtube.com/watch?v=3NdbN580HFY
VXDIAG GM Online Programming
https://www.youtube.com/watch?v=cmNETnv1TQc
VXDIAG GM GDS2 diagnostic Newer cars
https://www.youtube.com/watch?v=sTHKxWWf3H8
Old 05-16-2018, 02:19 PM   #18
Zeebins
Zeebins's Avatar
I've seen people on amazon and other forms using a 64bit version of windows as well as newer versions of windows such as windows 8 or 10. Some have more success than others so your mileage may vary.
Old 05-16-2018, 03:22 PM   #19
Mark_b
I saw some people doing 64bit installs but I have this old laptop and I have some work for it right away. I want to get up and running fast like you did.
My sonís 96 is still throwing a P0302 Cylinder 2 Misfire Detected. But there is no miss.
I have seen where people on here have done a crank angle sensor relearn and fixed this on a 96.
Not sure if that will fix it but I want to give it a shot.
Old 05-16-2018, 03:23 PM   #20
Windows 7, 8 and 8.1 for sure have a 32 bit compatibility built in. Windows 10 is questionable as it depends on which version you are running. If things try to open and crash there are logs to look at and that can prove informative.
XP and 7 are the safe bets to not be real difficult to start with.
GM Tech2Win software RobertGary1 S-Series Tech 7 05-01-2017 01:28 PM
autozone starter gamble failed RobertGary1 S-Series Tech 18 04-13-2016 08:17 PM
I have a Tech2 barbierij S-Series Tech 2 07-16-2015 04:06 PM
What is possible with access to a Tech2? saleenman S-Series Tech 6 12-12-2012 10:14 PM
Tech2 blen_to Astra Tech 4 10-04-2011 04:28 PM
